Pass B1
300VA will definitely work as you will be playing music not listening to sine waves. Music being dynamic needs far less continuous power.
125W x 2 @ 8 ohms
So it appears that 300VA trafo would suffice. What do you say guys?
Yes, provided he is not intending to stretch to max power which includes clipping which draws more power. Momentary power requirements are complemented by big filter caps. General thumb rule I used - RMS Wattage = 0.8 power factor X VA rating
His wife and neighbors will act as a safety feature not allowing him to raise the volume till clipping levels. LOL. Mine doesn't too.
Some good ideas for the enclosure / final assembly searched from various places on the net.
LL
I thought that is for one channel. So calculated X 2.
It is 125 x 2 @ 8 ohms and 250 x 2 @ 4 ohms. I'm also updating the list.
List updated -
22-0-22, 30VA
1. Gopib - 1 Nos
2. Stereorules - 1 Nos
3. Captrajesh - 1 Nos
4. AudioDoc - 1 Nos
5. Santhosh - 1 Nos
6. jetlag - 1 Nos
7. cmsajith - 1 Nos
8. gobble - 1 Nos
9. quad - 1 Nos
18-0, 30VA
1. AudioDoc
34-0-34, (Anything between 310 VA to 320VA)
1. CaptRajesh
The enclosure looks OK. Would be better if we include some space for the r-core too. Can you tell me about the enclosure manufacturer so I order a few more.
Hi Audiodoc,
This one is a DIY enclosure AK member Westend has made for his B1.I like its simple design.FM Santhosh knows someone in Banglore who can makes enclosures for us.
Sachin
Received the rest of the kit and it has been assembled. Now waiting for the other group buys. We can also try with Delta transformers. They even export their R-cores.
List updated -
22-0-22, 30VA
1. Gopib - 1 Nos
4. AudioDoc - 1 Nos
5. Santhosh - 1 Nos
6. jetlag - 1 Nos
7. cmsajith - 1 Nos
8. gobble - 1 Nos
9. quad - 1 Nos
18-0, 30VA
1. AudioDoc
1. CaptRajesh
Shall we go ahead? I will try to get exact quote and delivery dates to post here. Now I am out of town and return back next week. Till that time I hope to get transformers in hand.
List updated -
22-0-22, 30VA
1. Gopib - 1 Nos
4. AudioDoc - 1 Nos
5. Santhosh - 1 Nos
6. jetlag - 1 Nos
7. cmsajith - 1 Nos
8. gobble - 1 Nos
9. quad - 1 Nos
18-0, 30VA
1. AudioDoc
1. CaptRajesh
Yes, yes, yes. I'm in, I'm in. Post the cost details.
Could you please check the feasibility of the following trans from that vendor for my another project? If possible, please include these also (4 trans)
Yellow : Reqd trans
Grey : Alternative
Why is no one responding in affirmative?? @Omishra, any progress on the procurement?
List updated -
22-0-22, 30VA
1. Gopib - 1 Nos
4. AudioDoc - 1 Nos
5. Santhosh - 1 Nos
6. jetlag - 1 Nos
7. cmsajith - 1 Nos
8. gobble - 1 Nos
9. quad - 1 Nos
18-0, 30VA
1. AudioDoc
1. CaptRajesh
Yes I am in for the group buy of R-cores. If this does not go through soon will have to buy from alternate sources. Even have an enclosure set aside for the build. Same dimensions as my MyRef Rev E Gainclone (180mm x 300 mm x 60 mm is a perfect fit only problem is that I would mount the large caps off board). Believe that they make a great pre power combination.
One more query. It is safe to DC couple the My Ref if I use this preamplifier with My Ref exclusively.
