spirovious
5 GHz usually covers small distance I guess than 2.4ghzs, may be it.5Ghz it wont show
2.4Ghz wifi is working fine
Hello members,Oh my God, that's sad to hear. I will keep this in mind while dealing with them. I have been calling them in the numbers provided on the website since last 2 days. But, no one is picking up the call. I will mail them today. Lets see
This Pioneer VSX1131 model does not have dedicated sub pre for 2 channel.Hello members,
I am currently using AVR VSX1131 with 1 sub. I got another sub yesterday and connected to the AVR through subwoofer pre-out. Now, the problem is that my display still shows 5.1.2 instead of 5.2.2. But, i am able to hear the sound from both the subwoofer.
Even in the EQ section, there is only 1 subwoofer curve shown. Both the subwoofers are connected through Amazon basics subwoofer cable. My thinking is that the AVR should have considered both the sub as separate, not as one.
Would be grateful to get a preferrable solution from the members.
Thanks for your response. The product website had claim that it can be run in 5.2.2/7.2 configuration. Also, i have attached the picture of the model.This Pioneer VSX1131 model does not have dedicated sub pre for 2 channel.
It is just one sub pre out and parallel connection like" Y Splitter cable "(one Sub preOut given thru 2 RCA sub preout ports ).
Basically it is only one sub out
Yes.U can connect 2 subs as i mentioned in my previous comments.But it is basically only one output signal in parallel.it gives the same signal !!Thanks for your response. The product website had claim that it can be run in 5.2.2/7.2 configuration. Also, i have attached the picture of the model.
I was under the impression that 2 subs can be run through it. Now, is there any way to connect 2 subs to it?
What you see on display is input signal. If movie is recorded with 1 sub, then you won't see .2 .The product website had claim that it can be run in 5.2.2/7.2
Thanks. I was talking about the output signal.What you see on display is input signal. If movie is recorded with 1 sub, then you won't see .2 .
When I was reading earlier Yamaha AVR circuits, there was simply split of one SW channel to 2. New AVR may have dedicated 2nd SW output. In your case, MP3 is converted to multichannel and AVR not showing as .2 out. Its possible that codecs which converts 2 ch to multichannel can output only one sw out and not two.Thanks. I was talking about the output signal.
For e.g. even in case while playing mp3 audio; the input signal shows pcm, while the output signal shows "5.1.2". So, i was thinking that on adding 2nd sub, the output signal should show "5.2.2".
Is this the issue only with Pioneer AVR or does it happens with all 7.2 AVR?Sorry beforehand for asking too many questions.
Thank you for the explanation in simple terms.When I was reading earlier Yamaha AVR circuits, there was simply split of one SW channel to 2. New AVR may have dedicated 2nd SW output. In your case, MP3 is converted to multichannel and AVR not showing as .2 out. Its possible that codecs which converts 2 ch to multichannel can output only one sw out and not two.
Thanx for the info .. that was helpfulWhen I was reading earlier Yamaha AVR circuits, there was simply split of one SW channel to 2. New AVR may have dedicated 2nd SW output. In your case, MP3 is converted to multichannel and AVR not showing as .2 out. Its possible that codecs which converts 2 ch to multichannel can output only one sw out and not two.
Are any movies recorded with 2 subs? The higher end AVRs allow individual configuration per sub, but thats just to allow for overall EQ and calibration. I don't believe movies come with discrete LFE tracks.What you see on display is input signal. If movie is recorded with 1 sub, then you won't see .2 .
NOAre any movies recorded with 2 subs? The higher end AVRs allow individual configuration per sub, but thats just to allow for overall EQ and calibration. I don't believe movies come with discrete LFE tracks.
Congratulations , do write few words once you set itHello friends. Just joined the club with my purchase of Pioneer VSX-534.
These are paired with Taga Azure B-40 v.2 as of now. Going to add a Taga Azure C-40 for center channel and DNM audio satellite speakers for surrounds in a week or so.
Looking forward to exploring all the features and hope to find some help here if I get stuck anywhere.
1) Being a former Pioneer user (VSX 520) some high end models / brands of AVRs have EQs and thats the reason I moved to Marantz.Now I have a couple of questions for my fellow Pioneer owners:
- Do AVRs have equalisers? At times I want to reduce the rumble from my bookshelf speakers, but can't find a setting to do so?
- If not, then is there any other way to reduce the rumble, since there's no dedicated volume for LFE in a bookshelf speaker?
OK, so no equaliser in mine.1) Being a former Pioneer user (VSX 520) some high end models / brands of AVRs have EQs and thats the reason I moved to Marantz.
2) Would suggest to try to adjust the Frequency cut off in the bookshelf speakers. What is the current frequency set for Bookshelf speakers? 100hz or 60hz or 80 hz? Speakers set as Large or Small?
