spirovious
I have SP-C21 brand new center for sale.If anyone need ,please PM me.
Hi Guys,
Have you heard from Ashish regarding Speakers delivery ?.Last time i talked , he said by Feb 6th ,he was expecting consignment and by 10th custom clearance . I tried to call him personally but it is switched off from last 2 days. Even tried to call land line , seems to busy all the time
Let me know if u guys have any update
only in a single black ash finish.
Guys,This evening i got my Pioneer SP-FS52 :yahoo:
Burn in process , So for i think sound imaging is quite super,so is bass , clean treble though i haven't cranked it. It's super VFM
Please let me know anybody else got speakers and post initial impression
Hi Everybody.....I am New To this Speaker forum......
First I Want to Thanks Sash for this Thread....
I am also in the market for Avr & Speakers & interested in Pioneer 52 model.
My requirement is 75% Movies/Tv & 25% Music(Hindi film songs/classical vocal & instrumental & western Symphony).
I have Already posted New Thread for:-
Avr Denon X 1000/ E 300/ Yamaha Rxv 575/ Onkyo 525.
So please give any contact from where i can buy whenever it arrives in India.
I am from Mumbai Hope it might Launch here only. If You have any more information in this regards i request you please forward me.
Thanking You for your Information....
With Regards...
Rajubhai.
May be higher sensitivity. AVR outputs more power in 6 ohm speakers than 8 ohm.Strangely I found that the FS are easier to drive than the BS!
Strangely I found that the FS are easier to drive than the BS! Also, on paper the FS are rated as 6 ohm speaker, but in some tests documented at audioholics, it was mentioned that there are different ways to record this and as per some tests these should be marked as 8 ohms.
....<deleted>QUOTE]
Just a note that the ohm rating for a speaker varies by frequency range. The quoted ohm rating is usually some sort of average and how this is arrived at can vary.
This said, any decent amp can drive a speaker over its varying ohm range. Problems can come in if you crank the volume or when the ohm rating is very low (2 ohms or less for electrostatic speakers as an example).
....<deleted>QUOTE]
I am getting a wharfedale MS-100 5.0 speaker set with an impedance of 4ohms. I am planning to use a Yamaha RX-V475 receiver with it. Is that going to be a problem for the receiver or the speaker?
I'd wait for other gurus to answer this but I think the receiver would struggle to transfer more power when you play at high volumes. Having said that the Wharfedale MS-100 speaker set is actually a popular model in the budget range, right? So I am sure it'd have been designed to work with entry level AVRs.
Sorry to confuse you a bit more, but have you looked at other speakers in that price range? Why not audition the set mentioned in this thread? Aesthetically I'd rate them below average because of their humongous size, but sonically they are extremely good. I think price wise it'd not be very far from the MS-100 5.0 set.
