Please Help
aleemscorpio
Hi all,
May be I'm new to this Audio / Video forum. This question might look silly to you. But please provide me an answer.
I own an Onkyo HTC 3700. It's good but not satisfied with the effect.
I need the sound output to be like when we here from a headset or the cars equipped with good sound system. I want that kind. What I need to do. Do I need to upgrade my system or speakers.
Thanks in advance.
The system you have is entry level ......you can try to upgrade the speakers and check if there is a significant change.....
Most of us have changed systems over the years and have learnt through the years with good and bad experiences......hence the best is never rush but make time to audition all the systems and then make a good decision....
Thanks for the input, planning to upgrade the front speakers. Suggest me a good brand and model
Based on the specs of the avr....(power output and impedance), audition and check for speakers that meet your budget.
Tagas / Bostons / Wharfedale / Jamos / Pioneer (AJ series) can be considered.
