N nittoo New Member Joined Sep 17, 2010 Messages 1 Points 0 Location Narnaul Jun 2, 2011 #1 hi i want to buy 5.1 home theater speakers with digital(optical) input plz suggest me best speakers my budget is 8k thnx
Y yogeshtulsiani Active Member Joined Jan 25, 2010 Messages 115 Points 28 Location Mumbai, Bangalore Jun 3, 2011 #2 nittoo said: hi i want to buy 5.1 home theater speakers with digital(optical) input plz suggest me best speakers my budget is 8k thnx Click to expand... you might have to take the used route & get a logitech z5500
I imgene New Member Joined May 9, 2011 Messages 379 Points 0 Location new delhi Jun 3, 2011 #3 Try out Onkyo HTS528, they should be available in +2-3K of your budget. Also, try for Polk Audio RM6750
Y yogeshtulsiani Active Member Joined Jan 25, 2010 Messages 115 Points 28 Location Mumbai, Bangalore Jun 3, 2011 #4 imgene said: Try out Onkyo HTS528, they should be available in +2-3K of your budget. Also, try for Polk Audio RM6750 Click to expand... i think the OP needs amplified speakers with optical input. difficult to get an amp & separate 5.1 in 8k. slim possibility of getting used onkyo ht-s3100 htib around 8k.
