That's the servo switching as the voltage rises/falls. Normal.3. Occasionally I get some sound from the unit (like a small thud/thum). Is that normal?
The combined draw is probably too small to show up. Connect something with a larger draw and see if the display registers the larger load. You could also check with Vertex. They usually are quite responsive.1. The load is always showing 000%. I have connected my amplifier (70W), DAC and Chromecast audio to this.The combined draw is probably too small to show up.
Nicely summarized. One addition, Static Stabilizer = AC/DC Converter + Power Conditioner (generally available for industrial applications).1. Electronic Voltage Stabilizers - Manages voltage within a given range. Does not filter line noise. Handles voltage surges well, not current spikes. Not suitable for audio products because of microprocessor controlled switching circuit. Output sine waveform is same as input.
2. Constant Voltage Transformers (CVT) - Maintains a fixed output voltage (generally 230v). Does not filter line noise. Handles voltage surges but not as good as Electronic stabilizers. Does not handle current surge. Ok for audio applications. noisy. Output sine waveform is same as input.
3. Servo Stabilizers - Maintains a fixed output voltage using a servo motor. Audio products are sensitive to quick voltage correction as much as voltage fluctuations. Servo is continuous (read analogue) voltage correction mechanism. Does not filter line noise. Does not handle surges well (both voltage and current). Sometimes a small EMI filter is fitted to clean line noise (vertex does that when specified) which does a limited job. Sometimes used in series with a voltage isolator which provides fantastic surge protection and line noise filtering. Most suitable for audio applications. Both servo stabilizer and isolator are big bulky boxes and quite noisy. Output sine waveform is same as input or better with isolator (not sure).
4. Offline and Line Interactive UPS - Handles voltage stabilization and surges well. Provides backup till apt gensets kick in. NEVER use for audio applications. Output is stepped sine wave (may damage audio circuitry), limited dynamic range and switching to battery power is not seamless which introduces brown outs.
5. Double Conversion Online UPS - Provides constant voltage, fantastic handling of surges. dynamic range maybe limited so buy a higher power one (with at least 1.5x headroom - there is a formula to calculate it). Converts AC to DC and back to AC (hence double conversion). Pure sine wave, free of line noise. Provides backup too. Most suitable for audio applications but bulky, expensive, produces heat and has an internal fan which gets noisy over time. India made online UPS are compatible with gensets.
6. Power conditioners and re-generators - All the advantages of online UPS (minus backup). Very expensive, silent, great dynamic range and can be put into audio racks. Best for audio applications. Test with your equipment chain before you buy. Low cost ones may greatly inhibit dynamic range.
Go through this mammoth thread. You get most of your answers here. https://www.hifivision.com/threads/power-games-servo-stabilizer-cvt-or-online-ups.15235/
Very well explained sir. I was also doubtful how to give proper power to my system.1. Electronic Voltage Stabilizers - Manages voltage within a given range. Does not filter line noise. Handles voltage surges well, not current spikes. Not suitable for audio products because of microprocessor controlled switching circuit. Output sine waveform is same as input.
Single phase bought. 10 KV one.did you buy a 10 KV single phase or 3 phase servo stabilizer.
domestic connections are 3 phase hence was confused, so how did you manage to run the entire house wiring of 3 phase into single phase 10kva ?Single phase bought. 10 KV one.
Domestic connections are mostly single phase.domestic connections are 3 phase hence was confused, so how did you manage to run the entire house wiring of 3 phase into single phase 10kva ?
Here in Kerala domestic connections are mostly single phase. Upon special request will get 3phase connection.domestic connections are 3 phase hence was confused, so how did you manage to run the entire house wiring of 3 phase into single phase 10kva ?
In a 3 phase supply, the loads across the phases must be perfectly balanced. More the imbalance, more the voltage. I think it is impossible to have close to zero N-E in a 3 phase supply.Domestic connections are mostly single phase.
Mainline static stabilizer at the distribution board, for each individual phase. Look for one with a delayed start, if planning to use with AC and refrigerator.Just adding my requirement as its totally related.
Mine is a 3 phase supply. Am really confused.
I dont want an online UPS owing to noise issues. Planning to go servo/static way but confused as to how to protect whole home with individual stabilizers and this one for Audio
https://www.hifivision.com/threads/...urge-handling-3-phase-supply-split-etc.89675/
@john mathew how is your 10kv functioning now? Did it solve the voltage fluctuations?Very well explained sir. I was also doubtful how to give proper power to my system.
I bought a power Conditioner first but find the voltage fluctuation is not rectified. Then a technician advised me to go for a servo stabilizer.
I ordered a servo(Supra 10kv) 2 day's back. Instead of going for only audio thought of buying one for entire house. The price difference was not too much between 3kv and 10kv.
Waiting for the delivery now....
Yes. Voltage fluctuation issue is solved.@john mathew how is your 10kv functioning now? Did it solve the voltage fluctuations?
Please also share the cost for this 10kv unit you purchased
