Moved it from the other thread
A while since I updated this thread. I looked at options for me. First was to buy a minidsp and experiment with filters, then realised its a narrow solution and needs room acoustics correction before dsp.
SO did my research and with the help of FM ELango, decided on building broadband absorbers to the room. First intention was to improve the absorption coefficient of the room as my walls were thick concrete.
To build the thickest possible trap, decided to first build corner traps. Got inspired by Santy's build to start with a triangular trap. Ran into issues with stability as I was planning 8 feet high traps and the slabs kept falling down.
For the absorbent material, decided on Rockwool. While I initially was planning a very dense 96kg/m3 slab, but read a lot more reseach which pointed one of the keys to a successful broadband absorber is to have low gas flow resistivity. This is to ensure that the waves actually go through the layers than getting reflected. This is especially true if you are building traps > 4 inches.
Source -
So bought the following materials
3 bundles of Rockwool from Rockwool India 48 kg/m3 - Manal Rockwool - 950 Rs. per bundle of 14 slabs of 2 inch thickness
1 staple gun - miles TP10
A box of staples
Steel Mesh for panels besides the corner traps Rs. 35/sqft
Plywood - 2 sheets
L clamps to clamp it to the wall
6 kgs (18mts) of Spandex lycra to double wrap the traps - 3200 (Courtesy FM Kannan of Tirupur)
Sharp Knife
Gloves (used gardening rubber ones)
I had around 15 inches of corner space next to the screen, so decided to build a square pillar of 1 foot by 1 foot rockwool slabs with the ply adding around an inch. Wanted to build it till the ceiling but was difficult to clamp it as well didnt want to do a joint in the ply, so restricted to 8 feet.
Step 1
Cut the Rockwool slabs into squares
You will notice that unlike the higher density slabs, these disintegrate easily, so mask, gloves, socks and full sleeves are essential
https://drive.google.com/open?id=13E0aqFDM9anxqC1MRis_unbw7W7G3dow
https://drive.google.com/open?id=1bYxsqK1nxJf-qK7Kk5OLXHqzmz9K5_Rm
Step 2
Build the frame
https://drive.google.com/open?id=1gA_gWA1d8vO_ljAZFSp4KMQ99TzDQDK_
Step 3
Stack the rockwool slabs
Step 4
Cut the cloth, since its stretchable by around 10% so its nice to wrap around. However, at that height its still a pain to stretch and staple, so had to take the help of my better half.
https://drive.google.com/open?id=1DvJjlGJT1ISELu4rl66S42xxek3HG2CN
Step 5
Install in the right slot and clamp using an L clamp just to make sure that it doesnt get pulled down
https://drive.google.com/open?id=1i7Os6vIZD1lUqCKD-QBy_CW1iVprgveV
To build a panel (either horizintal or vertical)
Step 1
Build a frame of 4 inches depth and 1*0.6mts from inside which is the measurement of the slab
Step 2
Cover one side with Steel Mesh and staple
Step 3
Fill two slabs and cover with another steel mesh and staple
https://drive.google.com/open?id=1yxuKlnZzMZHkzLc9OHB2Rhoi9jpH17hK
Step 4
Cover with cloth and staple used around 2.5 mts to cover the full frame
https://drive.google.com/open?id=1noYAc6oQWV3WxiTPlyHV4qXYplwY8VHF
Tried to also make triangular for the rear wall, however, somehow the structure wasnt stable and the square one was taking too much space behind the reclines, so kept that for a later day.
Ran out of mesh for the other panels, to be put at the first reflection points.
Total cost - 8k for ply and labour, 3k for cloth, 3k for rockwool, 1k for the steel mesh. Rest are usable for other applications
