saikatbiswas82
I repeat, am a novice with room measurements & treatments..
You had mentioned this in your post..
I was trying to interpret it..1/4th thickness of the frequency..The OP measurements had a peak at 37hz.. So was doing the math (37/4= 9.25) and seeking clarity if the thickness of the bass traps should be 9.25 inches.. If my interpretation is wrong, help me correct it..
Agreed.. Since you have microphone to take measurements, was requesting you to share room response before Dirac correction, to see untouched bass response only as information..
Share, only if you like to, else please disregard my request..
The idea to trap a particular frequency,:
1. Calculate the wavelength
2. Divide that number by 4
3. Install bass trap of that resultant thickness.
In free air if we consider the speed of sound as 343.2m/s, the wavelength of 37 hz would be 365.18 inch. 1/4 wavelength would be 91.295 inch
In theory we may need approx 7.5 ft thick acoustic absorption material to trap 37 hz. Which is ideally impossible.
