Gentlemen, any suggestions for a good usb hub for powering external hdds for the pi?...moving away from powering the hdd via pi to a hub for better spindown...
I found a spinning hdd + transcedant power hub + seagate hdd is creating a spinning noise at the hifiberry output.I have found streamed music is much better with d pi.
1 final question,so the reason I'm buying this is because even though my Seagate slim hdd is set for spin down after 10 minutes in my distros via hd-idle,if I reboot or shutdown despite all my tries the Pi spins it up just immediately before shutdown like normal and then suddenly cuts power off leading to the abrupt parking which is audible...Its like something spinning abrubtly halted in the path and parking of the head is done abruptly which may affect hdd life i guess..I tried editing even the default shutdown scripts/reboot scripts and making my own scripts but owing to hardware it still happens.
https://discourse.osmc.tv/t/shutdown-script-for-hdd-eject/1267/4
OpenELEC Mediacenter - OpenELEC Forum - Hard Drive wakes up when shutting down? (1/1)
If I use an external hub for a non powered hdd will it continue to spin even if the pi is shutdown or after the pi shutsdown it automatically stops spinning,parking the heads normally after being idle and if no read is done on the usb?The current sound will surely not happen as the hdd would no longer depend on the pi for power
Basically just asking (powered hdd owners can answer) if the read is not done for a powered drive and no pc/pi connected is the hdd inside still spinning?If some fm can answer I will order the Quantum zero right away..
Also thanks for the other options,but I don't think I need a NAS box to justify the price points vs benefit logic yet.
A new Raspberry Pi project, setting up a personal DNS server on the Raspberry Pi for the explicit purpose of blocking ads on the entire network.
https://pi-hole.net/
Extremely easy, won't take more than 10 minutes, though will need customization and blacklists for long-term effectiveness.
It's not as good as Ublock Origins, but parsing their lists for domains to block will make the Pi Hole extremely effective.
Give it a try, will make your wife and kids happy when it blocks all ads on the iPad and the Smart TV.
Is there a way to play from You tube through Moode Audio other that airplay streaming ?
YouTube is for video. Moode is for audio.I have installed the Moode audio in Pi3 . Now if I want to play you tube songs on the pi, as I do with online radio stations ..is there a way to stream the same.
Thanks - I have a couple of spare Pis and I had been wondering what to do with them.
This one sounds like a go!
FWIW, this will be the 4th Pi in production at my pad hyeah:
