Am sure the answer lies somewhere in between, but with the software available today:
1. What are the advantages of doing only one, and
2. Doing a bit of both?
Have been playing around in my room (not yet measured ) but the more stuff is there, the more peaceful the sound is. I know this is quite the award winning line for the most banal statement ever made, but hear me out...
I briefly put a double recliner in the room and the highs definitely sounded more refined, but the bass was a little less sharper. When I brought back my single recliner back to the room, the highs became brighter and the bass became sharper... (didn't change Audyssey)
for reference, the beefiest part of both recliners - the fat shoulder-neck support part are almost exactly tweeter height.
More specifically, LFL's response to my question about the relevance of the sub crawl got me thinking... (And i do agree that he makes a fair point)
What is the best way to go about juicing up the best response in a room, especially small ones?
1. Purely rely on correction in a given room?
2. treat the room first and then run correction?
3. Do a mix of both depending on possibilities - do the least space eating panels, and then run correction?
4. Toole says regular furniture is enough if you do bass management -- can this be extended to room correction software?
HT in a small 10x12 room at around Rs 3.5L
Four is better than two. Of course. So, this gives me a lot of leeway for front, but not much for rears. The rear atmos I can not do anything beyond 25-30 degree without spoiling my viewing angle. But I can mock a height speaker like the Dali alteco to act like rear atmos.
www.hifivision.com
