sam9s
- Joined
- Aug 25, 2009
- Messages
- 5,251
- Points
- 113
The 1 GB GT440 is 4.5k and 2GB GT520 is 3k, which one do you reckon ?
Also for the processor would you recommend 2nd Gen i3 or the i3 540 would cut it for me ? the mobo would anyway be between 3.5 - 4k for both generations .
Thanks for your suggestions.
I think its the DDR5 version you are talking about. I have GT440 2GB ddr3, that was/is a bit less expensive than the DDR5 version. But if its still hovering the same 4K mark, I am surprised, maybe coz its the fav gpu among DIY HTPCs ...
i3 540, more then sufficient, but I guess, the prices are more or less same, isnt it ... I might be wrong.
How about this deal INTEL G41 MOTHERBOARD + INTEL DUAL CORE PENTIUM D 3.0 GHZ CPU + 2 GB DDR 3 RAM ?
I can add a dedicated GPU GT440 to it, so in total it'll cost me 10k which is quite decent? Would this setup able to handle (stereoscopic) 3D playback from Bluray directly ?
eeerrr dropping straight from i3 to Pentium D ... lolz ...
I'd say refrain from Pentium D atleast, even for an HTPC. See if you can manage to find any C2D/C2Q, they are dirt cheap now.
Try this one http://www.ebay.in/itm/Intel-Core-2...2?pt=LH_DefaultDomain_203&hash=item3373f33884
2GB ram is good enough. (even DDR2 will easily do)
