Guess I m narrowing down on BR6 + marantz pm 7004.
Pre purchase blues -
Is BR6 at 50k a good buy?
would a 70 w 8ohm amp match 150w/6ohm speaker?
Need help..
Will you get confused if I told you Yamaha AS500 85W x2 or 700 can also be a good option for driving MA BR6
Sent from my iPad using Tapatalk HD
Will you get confused if I told you Yamaha AS500 85W x2 or 700 can also be a good option for driving MA BR6]
FS without audition is too risky to my understanding ! For eg in my case Tannoy V4 was 5 star and KEF Q500 highly recommended and yes they are good and on top of my list, but BR6 is what gave the perfect balance to my ears. There are others who swear by Mordunt and Paradigm, but found them to be subdued.
Each to his own ear I guess! Wish you luck in the FS hunt...hope my journey expressed in this thread gives some help..
Meanwhile looking for ideas on 650A and PM7004!![]()
BR6 are almost done...would be finalizing next week I guess (unless another sound comes in the way!!..though don't even feel inspired to hear others again)
Need help..
How does it matter if Monitor Audio BR is OLD series or NEW?
Its not a software where new version may mean more fixes and old version = more vulnerable.
What sounds best to you, you should buy that.
If Tannoy it is, then Tannoy it should be ...
Anyway they have rave reviews in favor of them.
Tannoy, Quad, Wharfedale, Monitor Audio, Morduant Short are supposed to have the "British sound" - which means all frequencies are reproduces equally loud. And there is a slight roll-off (less volume) in the extreme ends. - this makes the midrange stand out.
But you won't sound as lively as the american sound.
On the other hand - the "American sound" = boosting the bass and treble ends - so that the music sounds lively at lower volumes, but it may sound fatiguing at louder levels.
