keith_correa
So if I write a file from RAM to the "noisy" SSD, read the file back from SSD, compare what I read, back to the original source in RAM, the delta would be "noise"?
Thank you for giving voice to my thoughts succinctly & to the point. & Also reaffirms my faith that there some good & well-informed folks as well on Hifivision.There is so much misinformation here - it is crazy. This item is pure snake oil. The SSD controller is an arm Cortex CPU and it runs sophisticated code in its firmware to make sure data integrity is maintained. It even detects and isolates any bad blocks due to wear. There is built in error correction. Otherwise what you write and what you read off an SSD will be very different which is never the case.
Timing issues occur in real-time transmission only when clock jitter can cause unrecoverable errors where there is no error correction such as spdif and to some extent USB. That is absolutely not the case here where error correction is in full force and the data pipe is nowhere close to saturation.
Here data is first read into the SSD cache, error corrected and then sent to the memory location pointed to by the host CPU. The total amount of audio data read is miniscule compared to hordes of data read for say something like a video game. If there are no issues there, for hell we can be sure there would be no issues with audio files.
Also anyone who uses SSDs extensively knows that the realtek controller on this SSD is a piece of crap. One is way better off with a WD SN850 or a Samsung 980 Pro.
If only they spent more on actually improving the firmware of that controller, it would be far better off than adding bells and whistles. Every realtek product is affected either by firmware or driver issues of some sortThank you for giving voice to my thoughts succinctly & to the point. & Also reaffirms my faith that there some good & well-informed folks as well on Hifivision.
Lets get to the snake oil in these comments:Despite "The Audiophile SSD" being the current poster boy for Audiophile extravagance, I am not so sure I would write it off in such an off handed manner..... I think it deserves to be heard, before passing judgement.
There are several tech innovations that deserve a listen.
An LPS feeding an entire PC with about a dozen SMPSs on the motherboard, feeding individual sections, is not just OK, but desirable.... But if an SSD takes juice directly from the LPS, it is snake oil ?
Femto clocks are great everywhere, but on the SSD, its Phoo Phoo ?
SSD Controllers are considered the key for SSD performance, but when a custom Controller is implemented in this SSD, it attracts ridicule ?
Running the SSD for peak performance and endurance .... (pSLC) mode ... is acknowledged as being good but unaffordable for PC work, yet when implemented for SOTA Computer Audio its bullshit ?
Lets think this over guys, and not join the heard in ridicule ....
That is a given - You can't build a voltage regulator for a modern CPU that consumes 250W with linear regulators - it's simply not possible physically. Only way around it is to get a low power CPU which can be powered by a 2-3 phase regulator. Also these operate in the MHz domain - the noise they generate will be in that range not audio frequency.When I said SMPS, it was used loosely.
The Voltage Regulators that you refer to are SWITCHING Voltage regulators, and the key issue here is the generation of switching noise by these SWITCHING Voltage Regulators. Actually they are SWITCHING DC to DC converters... Far more Noisy than Linear Voltage regulators, or the DC available from an audiophile grade Low Noise LPS.
The Audiophile Grade SSD has the option to feed it "Clean" 5 VDC via a low noise LPS, rather than getting this jiuce from a switching regulator or a PC Multi output voltage SMPS.
Clearly you do not like Realtek.... But Realtek has a Great history and rich experience in PC Audio. I suspect there must be good reason the Realtek controller has been chosen for an audiophile SSD, rather than use the stock controller..... You may or may not like his choice of Realtek, but clearly he has made a conscious choice, based on factors he has deemed important for an audiophile SSD. Again, I would not call a decision I disagree with, as snake oil !
You also have your views against (pSLC) mode. The computer industry does have proponents for (pSLC) mode, ofcourse with its overhead costs of greatly reduced capacity. It would be unfair to dispose off pSLC as snake oil in one wide stroke.....
To clarify my stand, I am not saying that the Audiophile SSD is the greatest development since sliced bread.... Just that there may be serious effort that has gone into the development, and I feel it unfair to pass summary judgement... particularly as an audiophile who has an open mind on the subject and the effort put in by the developer.
You can feed 5v and 12v DC directly from a linear psu to any SSD with a sata connector - actually I'd argue SATA is a better interface if you want to get there as it is completely isolated from the motherboard in the first place compared to NVMe and only connected via a SATA cable. You can still get real 2 bits/cell SATA drives (Samsung 850 pro) which will be more than enough instead of SLC emulation over TLC. The endurance of MLC is exponentially better than TLC. The transfer rates that SATA offers are more than sufficient for any kind of audio file.
Realtek has no history with PC audio - it makes garbage audio chips that sound like $hit and garbage network chips that drop connections randomly. Any internal sound cards worth their salt use CMedia chipsets. Realtek's NVMe controller is equally bad - loads of people complaining about sudden disconnections. Only thing realtek does is sell things for cheap - ultra cheap. Probably that was the only motivation here.
I'll keep an open mind to products that actually provide me some benefit not sell snake oil.
Digital system were originally not built for audio, but for critical and non-critical data. You can easily and accurate identify any alteration in the data. Data were being used and transmitted over long distances. It is quite normal to assume that errors would occur in this process. At the same time, it was very easy to introduce error identification and correction algorithm into the data packets that could be verified by the receiver. Checksum is one of the simplest algorithm, though now there are much better and more robust algorithm.Wonder why they have error correction on HDDs and SSDs and for Digital transmission too....![]()
No data is lost, whether HDD or SSD, irrespective of the storage medium, period.No data is lost, whether HDD or SSD, irrespective of the storage medium, period. There are enough guard rails in a purely digital domain at both h/w, s/w levels to counter any bit of corruption during transmission. But in a mixed environment, it's not only the bits that we receive from the medium but the line noise that accompanies it also contributes a significant role. If these line noises are not taken care of, they have the potential to compromise the DAC's ability to reconstruct the Analog signal properly. The Audiophile Grade equipment tries to minimize this effect of various noise on the final Analog signal via different techniques. They will not re-invent how data is stored in the disk but try to reduce the line noise passed to the audio chain. But again, it's debatable how much we can hear the difference.
You are missing the point; no issue with the 250MB of music; it's a bit-perfect. However, when those 0 & 1 arrived at the DAC, they also carried line noise with them, and this noise affected DAC's ability to reconstruct the original signal. Where is that noise generated? It could be generated at the drive's storage/USB/power controller. Is storage in question here? No, and as I mentioned before, they are not inventing how data is stored in the storage medium—but employing different techniques at various stages, probably at the storage/USB/power controller level, to reduce this line noise. Cheers.As I said before, if it can store a 500 page document file without errors, why should it have issues with a 250MB audio file?
