Back with another project “Solstice” MLTL.
A small introduction of this project. This kit is designed by Mr. Jeff Bagby. The drivers used are from Morel. This kit is available for purchase from part express including complete enclosure (without assembly). In this case we had Drivers and Cross-Over (assembled on PCB) We did not had the enclosure so we had to do research online and get the required dimensions from the persons who already own this kit. After getting required information / dimensions, we went ahead for the built. The person who has given me this project has complete faith in me, He also assured not to worry if something goes wrong after all we are doing this project based on inputs / information collected / searched online.
Because even if you own the kit, part express dose not provide dimensions of enclosure. they will provide only built up guide and a video of built shard on youtube,
Below are the words from the Legend itself.
"This is honestly one of the best two-way designs I have ever done. I can find very little to fault. Not only is the response exceptionally flat, but it sounds very balanced, with fantastic resolution and detail. Vocals are beautiful, as are instruments. Bass is full, extended, and very impressive. Nothing stands out, it is just sound honest and accurate… It is really a high-end speaker worthy to be compared with systems that cost several thousand dollars."
It will be a milestone for me if the project is success and i know we will make it success. The final finish is yet to be decided. The construction of this enclosure will be 18 mm MDF as recommended in kit.
The Drivers are
Morel TiCW 638Nd Titanium Series Hybrid Cu 6" Woofer 8 Ohm
Morel CAT 308 1-1/8" Soft Dome Tweeter
Below is the photo of this Speakers, this is how it looks after assembly. (Below photo of enclosure is not my built)
Today i have got all the baffles. All cutting has been done on CNC router except for the grooves. Today I have started the assembly of this Project. Below are photos of today's work.
Enjoy guys. Cheers...
The Drivers are
