rikhav
- Joined
- Mar 27, 2008
- Messages
- 2,671
- Points
- 113
Also the characteristics of the Juli complemnt my amp well
Hi Ali,
By characteristics you mean the sound signature of the Juli?
Hi Ali,
the M audio vs the Xonar does nothave many reviews
but the Emu 1212 is not only better speced than the Xonar but most reviews have it topping the xonar
the reason Emu cards are not preferred isbecause the mixer software isdifficult to use.
there are driver problems. a PC nut would easily sove it but due to these issues other cards are preferred over the Emu
However if you can corretly use the software and driver the Emu i belive would top the Xonar
however ROC does think the opposite
im just stating what most users on head fi and comp audio asylum believe
yes the Xonar should top the Juli on analogue audio, however not by much.
on my basic rig i may not tell too much diff hence i may lean toward the Juli
Thanks Magma.
Any links comparing the Xonar Essence with an EMu 1212?
some in head fi forums
mixed views
but most dont seem to be impressed enough to change from their current emu to the Xonar
they still prefer the Emu 1212 over other cards in the sub 200$ budget
The new flavour however is the Emu 404 USB which is not only a usb soundcard but can also be used as an external DAC
Some say that the cleaner power supply helps it sound better thanthe Emu 1212, some however dont agree
as i said mixed opinions
All said and done the Xonar is hardly adviced by them over the above 2 emu's
(of course its head fi- so the guys are intersted inthe OP amps and ampli stage too)
techenclave has are very own ROC praising the Xonar over the emu though
mixed views
the only reason im considering the JUli is because i cant seem to get my hands of the Xonar ST!
Emu 1212 is a great card but ive been warned by more than one senior about complicated drivers
thats something i hate.(though i know i can learn it ) i dont like the idea of having to do it and keep fiddling with the mixers and being unsure whether i have it right or not !)
ive been offered an M audio 1010 too for a good price
im not too sure what to do
get the M audio the juli or wait patiently till i can get a xonar st ( i dont know how long though!)
If you have soldering skills, that would be helpful as some of the better chips require use of an SOIC-to-DIP adaptor to use here, which means soldering a surface mount part onto the adaptor. It's not exceedingly difficult to do, though .
Does any one know where I can find these opamp adapters in India or better in new delhi ?
If It is certainly not a bad card, but there are better options if one were planning to use the analog outs. That seems to be what a lot of people seem to think.
well there is only the Emu 1212. 404 and the xonar from what ive read
which would better the juli on analogue
(the juli is at par or better than the M audio 2496 or the 192 from my research even leaving the Echo mia Midi behind)
what have you read?
wouldnt a Peter daniel or even a keces or used stello dac make more sense than the emu 404 usb
if youre looking for an external dac?
i would think so!
cranky has the 1212
he hasnt actaully comapred it with a Xonar
i thin it was he who suggested i go for a juli rather than an emu in the absence of a Xonar( driver issues and also for my basic rig i wouldnt actually notice the difference)
