Sony DVD Player help!!!
kaptan
chennai
I have an sony dvd HTIB
Model No: Sony DAV DZ 290K
query:
1. I want to use it as an dvd player with my AVR. Will this be possible.
I has an HDMI output. I dont no its only meant for Video. I know HDMI can pass both audio and Video signal.. I dosnet have optical or coaxial output since its DVD HTIB.
Techies help me .
Hi, try connecting the HDMI output to the AVR and check whether sound is available. Some models won't support audio over hdmi.
Thanx baijuxavior
I didnt try it. If it works I will use as dvd player or other wise use the total setup for my PC.
If any body know about this. Help me.
I used the dvd player to play dvds but the quality is very bad. The same vob file played in my media player the quality was excellent since it sends the dts audio. while the dvd player sends 48khz/ 16bits which is converted from DTS.
