Sony Tablet SGPT 113
Good spec for the price. In short a close competitor for Samsung Galaxy Tab 2 trading around 19k
pros:
+ nice/super display
+ very decent battery backup
cons:
- weight (should not be a concern for this model)
- OS version
- HDMI out
unknowns:
? Is OS upgrade available. Make sure you can upgrade to JB, its superfast.
? Is Google App Store available - One of my friend has HCL Me U1 which does not have it :)
? Will it play MKV - It should but just make sure
? pouch or carry case - These gadgets need good carry case which are additional accessories that might pinch your pocket
? will the display fade in bright light (not to worry if you are going to use indoor)
This festival (Nov/Dec) there are bunch of tablet launches - Nexus 7 upgraded, ipad mini, something from Acer, MS tablet etc that are likely to be in the same budget you may want to consider.
pros:
cons:
- OS version
- HDMI out
unknowns:
Thank you Ravikumar.
OS upgarade is available, according to Sony site. As for JB, I need to check.
App store is available.
Not sure of MKV, but don't really need it.
Pouch or case - will get it.
Display is fantastic even in bright light. I checked the 7" model and not this one.
Finally, the MRP is Rs. 29,900 and I'm getting a sealed piece at 20K. Looks attractive. Guy has only one piece. I think I'll take it.
Regds
If you like it then buy it ....because the mobile and tablet market has no stability ....softwares and OS is changing almost everyday.......recently bought a Sony Xperia Neo L and like it for the price..........
