Hello All
Following are a few of the Stands ive built
Granito
The top Slab/plate shown in the pics above are recessed so that
the top nut is flush with the top surface of the top plate
Pics shown are Work in progress pics when recess was NOT
completed
SAL - Alif
SAL - Be
Other than the basic stands above a lot of customisation may be done
Top & Bottom plates/Central pillars made to Materials (SS,AL,MS,Wood etc) and SPecs as per Choice and dimensions
Finish ranging from Matt Buffing, Anodising, to powder coat/Paint and PU coating and sand blasting ( for higher
cost stands)
Top plate Sandwich : weherein the top plate consists of MS or granite plates with Acrylic in between
Inserts on Top plate which can allow speaker levelling.A request is also being looked into where threaded inserts
may be provided to bolt the speaker to the top plate
Cable management
Here is a Centre Channel speaker stand made for a member
His speaker measures about 25inches * 12 inches i think
MSR - Centre
the stand weighs in at 28kgs unfilled ( actually i dont think it needs to be filled at all , though that option has been given )
Its a lovely finish full Matt Black Fine Texture ( sand blasted) finish
I hope to soon post some Bookshelf speaker stands that are made along these lines
Edit : i do the above as a hobby and since i have the means ( machinery equipment and vendors ) . certain friends have adviced i do this for members here.
I would consider that
Update 17th July
Here are Some stands built for members
Please note i have not posted ALL stands i have built for members only the ones that are different so buyers please dont intepret this as partiality
SAL- Alif RND
Here is the vesrion of SAL Alif in a 3 inch Round steel central column
Finish is black matt ( premium sand blast)
Each Stand weighs in at 13-15kgs (approx 30-38 Lbs ) Unfilled
PSB
Here is a stand ive simply called PSB since it closely resembles a stand i saw at lakozy for the PSB B25's. (im sure if dinyaar sees these hell agree that this stand better the one we saw in all aspects)
These are large bookshelves and hence the top plate is larger to accomodate
Built for a customer with the PSB B25's
The base plate is also a lazer cut Trapezoid ( shape "c" i think). Looks pretty cool
AXON SQ
Here is a stand specially designed ground up for a member who wanted somethin that looks good aesthetically and also wanted cable management. The stand has larger than normal base plates and top plates as per requirement
I have selcted shape "d" for the baseplate
The base plate has been lazer cut to dimensions unlike regular milling or manual gas cut. A good amount of work went into this
This shape was chosen as it looks and functions better than all other shapes considering the pillars we have chosen
There is a large square 3 inch column in the front and a 1 inch circular column behind it for the cable management. Hence this shape with a broad front which tapers to the rear matches these column arrangement very well ( large column in front with a smaller one at the back). Also the straight edges in the front match the straight lines of the square column better than shapes which has curved edges
I think this base plate should also match the customers particular speakers which taper off towards the end.
Lastly this shape allows us to keep the CG dead centre which works well for this stand the weight of cable management column offsetting the taper on the base plate
Heres a checklist on stand building you can refer when building your own
Attatched is also a list of prices when ordering for me
(These are tentative and may change with times)
