square_wave
I don't know what you are smoking. But if you keep smoking the same thing, you will surely smoke the speakers or amplifier very soon.
What i learnt and then experienced myself, the right way for a sub is not More Bass but Better bass
If you have heard Livingston Tylers "Grandmas Hands", you would know its an acapella ie no instruments, but with a Good sub or a decent Floorstander you can also hear a thump which comes due to him hitting his foot on a wooden box he is sitting on. This is part of the music and most bookshelves and some FS will not even let you hear it. but with a good sub you hear the rhythm
My favourite example is Eric Clapton "Unplugged" where most songs have a drum at around 25 hz (I have measured this) and this goes missing very often in systems and once you hear it you cannot hear the song without it.
In both of the above, its not about the thump impact, but the quality and texture of the same which makes is part of the music.
Please listen to what the other members are saying. The ls50 are absolutely a superb speaker. Change your AVR and get a good integrated. Listen for a while. If u need more bass, sell the AVR and the ls50 and get something like a dali or Elac. They will give u enough bass. If still you need more, then buy a subwoofer to go with the bookshelves. The ls50 are near field or monitor speakers with excellent midrange and imaging.
Also, it would be nice to pen down your thoughts in ONE message instead of writing 5 messages one after the other like a watsapp chat every minute. We know u are excited! Congratulations and good luck with whatever u choose to do now!
How ever when you r in a party mood or want to hear that one groovy song , it just doesn't give those thumps
Thanks Raghu@RAJUSH26
You have a nice setup there. Bring the LS50s up to the edge of the platform.
They could do with a little more separation, but then you would need stands.
Even so, they will have asymmetrical back wall bounce off due to right glass door.
The manual says ideal separation from back wall to back of speaker should be 20".
Other wise use those foam bungs as necessary.
Hear them out for music; they do shine in that avatar.
They take a while to get used to as they are monitor speakers.
You may change your mind about the sub for now.
When upgrading, try to allocate funds for amp/AVR upgrade along with sub.
Raghu
Please consider a Powerful Stereo Amplifier.View attachment 36666
Listened to all the peers here , many many thanks for all the guidance and pls continue to enlighten me on any blunders I may commit on my audio audessey.
Removed the Sony speakers and only connected the kefs.getting used to them and falling in love with them more and more.its kinda slowly showing why it's such a respected speaker.
It is not about bass.It is is about filling the lower octaves for a richer fuller sound with body.Vocals and Instruments sounds so much better with a properly integrated sub.Even floor standers sound lean in a reasonable sized room without the sub in my limited experience.Rajush, your set up looks quite pretty. But unfortunately, your speaker placement is not correct. LS 50 is rear ported, meaning, it needs space to breathe on the rear side. Leave at least 2.5 to 3 feet away from the wall to get the LS to work better. This maybe the reason you are not getting the required low end. My experience tell me that bookshelf speakers sound best when placed on a good bookshelf speaker stand. The sound changes a lot to the better side. Look wise, it may not be as neat as your present arrangement. But, here sound is what matters. And once again, bass is not everything. I would never suggest a sub. Its not worth the investment. But a good stereo amplifier is a must. As you said, if you are slowly falling in love with it, it will stay. Those which impress you straight away, will bore you quickly too.
All of which is right, but the poster you're addressing this to won't listen. Mostly because he hasn't experienced it himself. You're welcome to try to convince him though, when multiple others have tried. And failed
Properly integrated sub.......that is the biggest problem. We never get it integrated, forget 'properly'.
Which can be on the sub, no AVR needed.Sub integration is definitely possible with bass management.
<snip>
This hobby is all about having as many options at hand and choosing when to use them.
I've had no issues.
When I was 48 I was anti sub. To the honorific, lost status well over half a century ago ...That may well be, but the really important question is: Are you 48 or older, baby?
And yes.
To options.
And open minds. I was absolutely set firmly against a sub in my rig, till I heard a well set up one.
Ciao
GR
Hear it out with your speakers in your room if possible.A fellow member offered to sell a Rotel for 26k, is it good for the kef's.
