suggest 32 inch LED
joshiks7
solapur
Kindly suggest me best TV .....
1. LED
2. 32 inch
3. For bedroom
4. 7 feet viewing distance
5.Confused.....Full HD or HD or HD ready? Does it really make diff. at this distance for 32inch?
6. Mostly TATA Sky
7.Budget-40k
1. LED
2. 32 inch
3. For bedroom
6. Mostly TATA Sky
7.Budget-40k
40K budget is a bit higher side for 32 inch tv's nyways.. at this price.
go for either Samsung EH5330 or Sony 32EX520
my suggation is for you
1. LED
2. 32 inch
3. For bedroom
5.only Full HD (1920X1080)
6. use set top box -Vidiocone HD
7. In your Budget you can see cinema 3D LED TV (LM 3410) Price is 40K
Dont buy a 3D TV for 32 inch. Its absolutely waste of money. Also LG LM3410 is HD ready so ur 3D viewing would be not so good. You wont be enjoying much.
Always buy a TV which has better 2D (Standard+High Definition) Quality as this will be used by you the most.
As per Infibeam Prices
Sony 32EX650 - 44k
Sony 32EX520 - 42k
LG 32LS5700 - 41k
Samsung 32EH5330 - 38.3k
Better go for Samsung 32EH5330 as pricing is good at infibeam for this model . plus it has COD + FREE SHIPPING + 30 Days Replacement Guarantee
Do a demo of 32EH5330 at your nearest shop and I am sure you wont be dissapointed
But at this budget of 40k if you want 42 inch den better go for plasma
at 40k you can easily get samsung/panasonic 42 inch plasmas......why settle at 32 inch.
and toshiba 40 inch lcds also at 42k.
at 7 ft distance 42 inches looks fantastic.
if want to stick at 32 inch..must not waste money and buy a semi hd lcd any sony 32 inch semi hd at 25k..............
experiment all of the above and decide according to your picture liking
+1 here. Buy a semi-HD 32" LCD (not even an LED) or go for a 42" semi-HD plasma. Believe me, a 32" FHD does not make any difference. Go and have a demo and you will see for yourself. The only things is that the mind is playing tricks on you and telling you that you are not buying the best.
1. LED
2. 32 inch
3. For bedroom
6. Mostly TATA Sky
7.Budget-40k
Go with Sony 32EX550.
Thanks friends,
I am taking panny 42ST50 plasma for living room. For bedroom, i felt 42 inch to be little too big. But surely i shall go for HD ready, but not full HD.
Among sony, LG, panny----which has the best picture for SD TATA sky viewing?
best is demoing 32 inches with sd channels...in the showrrom.or just for sd content 21 crt at 8k is not bad either...no joke intended.
kindly suggest me exact 32 inch models of samsung, sony and panny?
How many minimum HDMI terminals should be there in TV?
Which should be preferred?-----
1.Panny TH-L32X50D
2.Panny TH-L32XM5D
3.Panny TH-L32EM5D
4.panny TH-L32E5D
----I am confused of various features?
You could go with a basic LCD. No need to buy an expensive LED. You could go for a Sony Bx or Cx series. Minimum 2 HDMI ports are required/desirable.
Sent from my GT-I9100G using Tapatalk 2
If I want to watch HD Nat geo channel on TATA sky and I have 2 TV'S (32 inch)...one is Full HD and other only HD ready, Whats real life difference in picture quality if I am watching from 7feet distance?
Almost no difference.
perfectly suggested.for sd channel and daily soaps a basic lcd and 2 hdmi port is real enough.
1.Panny TH-L32X50D
2.Panny TH-L32XM5D
3.Panny TH-L32EM5D
4.panny TH-L32E5D
Iam using pana 32E5D.best value for money acc. to me.amazing pic quality,Supports all file formats via usb. bit costlier than other brand models(except sony) but worth it.
