suggest 32 inch LED
Depends upon how much is 2K valuable for you :)
But since it is for your bedroom, I will suggest BX350 only.
hi,
Its not question of money, but is it worth really? Whts exact difference between BX350 and CX320??
The Sony website will be able to tell the difference in specs. But that means nothing really. One should go and do a visual side-by-side test. Since the models in question are both Sony, that should be easy.
Honestly, I would not say that CX is a head above the BX.
hi,
Toshiba 32PB200 LED 32 inches Television AND Toshiba 32PX200 LED 32 inches ----how are these ones?
Price is less than 30k with good features, any user reviews?
How reputed is TOSHIBA?
sure friends, any more info on TOSHIBA?
Iread in one review that TOSHIBA lcd's are bit difficult to wall mount as all ports are behind, is it true?
hi friends.
WHy this model---32 (81 cms) NX650 Series BRAVIA Full HD LED TV----is so costly?
What are the advantages?
Is it really worth to purchase if any one affords?
for 32 inch go for sony led semi hd.....even you can buy lcds also....around 25-27k.....dont invest much on a 32 incher....as on a 32 inch its impossible to tell whether semi hd and full hd.....also 3d is not enjoyable in a 32 incher.....
I had this same question of looking for 32inch LED. i tried samsung led series.
There were basically 32ES5600 and Ua32D5900. I am not looking for 3d content neither internet browsing. The main concern is Full HD along with display brightness, and support of different formats. Also Ua32D5900 is not listed on samsung website, so that confuses me
Best option will be to view the various models in showroom, side by side.
- Check with SD source
- Check with HD (DTH) source
- check with blu-ray source
- Change picture settings to normal (showroom pic settings are set as dynamic/vivid)
Go with the best model that fits in the budget. In my opinion, 32" is a size that is just a replacement for 29" CRT. I have not seen any significant difference in performance when watching DTH, especially SD. Even with blu-ray, the LED was not miles ahead. Hence the higher price of LED in this size is not justified. Save money now, and keep the money for a future/larger second TV for living room. On the other hand, if this is already a second TV, why spend too much?
