suggest 32 inch LED
Check sony 32EX330..it's a direct led model with WXGA(1280X768) resolution...it will be more vivid than CX350 ccfl model.
My suggestion.....Go with Sony bx350. If you want only full HD, go with cx420. There is only 2K difference as I said earlier. I couldn't notice any difference in picture quality between the direct LED models and the LCD ones from Sony. So why pay extra ?
@lake1988: Are you sure that 32EX330 resolution is 1280*768? Even the bx350 is WXGA resolution. But if you download the manual from Sony website, the resolution specified is WXGA (1368*768).
Actually when u refer to computer resolution wxga means 1280X768...but while refer to television resolution wxga means 1366X768.
I had this same question of looking for 32inch LED. i tried samsung led series.
There were basically 32ES5600 and Ua32D5900. I am not looking for 3d content neither internet browsing. The main concern is Full HD along with display brightness, and support of different formats. Also Ua32D5900 is not listed on samsung website, so that confuses me
Does anyone has idea about my query ?:(
Guys, has anybody tested ARC using Panasonic L32C55D? Any idea if any 32 inch lcd/led supports ARC in Samsung 4 series or Sony? Alternately, any suggestions on a 32 inch lcd/led with 2 hdmi (without arc) and 1 optical port in panny, Sony, Samsung? Budget 30k..
Thanks, Anshum
Lg led is best as it has very
good sound+great media player (play almost all known media)
you will be able to plug and play external hard disk
without any problem
3 hdmi USB optical all option
Full HD on 32 inch may not make much difference from a normal viewing distance.
HD Ready: 48.97 PPI, 0.5187mm dot pitch
Full HD: 68.84 PPI, 0.369mm dot pitch
