I was content with what i had for a very long time and was drawn into so many other things that i did not seriously participated in anything on HifiVision. Apologies.
Now, i would like to buy a pair of Bookshelf speakers for my living room which will be paired with the following setup :
CA 340 CD Player/Iphone (bluetooth) -->Beresford DAC --->Dared SL2100 Preamp ---> NAD 355BEE ---? Speakers
I have a Mordaunt Short 302i sub to complement the lower frequencies as i chose to
So far i have been using my 10 year old Mission M32i which I now find not so good after accidentaly hearing some other speakers and hence the upgrade.
I also have a Fostex 103E based DIY Zigmahornett speakers as well and i keep shifting between Mission and this one just for a change.
My budget is not more than 20K
I have started youtube listening for some speakers in this range.... no audition as yet
Boston Acoustics A25 or A26
Q Acoustics 3020 & Concept 20 (not in this range though)
Wharfadale 220
Polk Audio S20
Dali Zensor 3 - may be not in the range again
I need clean & crisp sounding speakers with filling sound/body which should not make me tired listening to them. Bass is not an important criteria as I will use the Sub as required.
My Listening area size is 12 x 12 with wall behind and in front. Right side is french glass doors and Right side open to the Dining and Foyer area
Can you guys suggest a good pair in this range. Thanks.
BTW, I am from Chennai and suggest some good Dealers as well or Hifimart is the place to go ??
Swami
Wharfadale 220
Polk Audio S20
Swami
