Suggest step down converter for BA soundware 2.1 digital cinema
gilagamesh
Hi guys
Can anyone suggest me a good but not too expensive step down converter from 220v to 110v for my Boston Acoustics Soundware 2.1 digital cinema speaker system.
It's very urgent. Your comments are very much appreciated.
Thanks in advance.
hi az2325,
On the back of the sub woofer it says 120v - 60hz 4.0A, T4.0AL/250V.
On specification it says:
Recommended Amp: 10-100 watts.
Total system wattage : 250 watts.
This is a heavier system than i thought. I was thinking for something below 100w
Maxine is one brand which i have found to be mentioned earlier in this forum for such loads.
Easily available in ebay.in
maxine | eBay
Antony
Did you end up buying something? I have a BA setup and will require a similar transformer in the future, hence interested :)
