Suggestion for avr to go with Taga harmony tav 606 v3 5.0
n52n53
Katni
I'm getting the Taga harmony tav 606 v3 5.0 speakers. Kindly suggest me an avr to go with it at around 25k price range. (movies :music - 25:75)
Also, I'm still confused about whether to buy a complete 5.1 package(yht 299) or a 5.0 mentioned above and avr for around same price. I've heard that it'll do the equivalent work of a bass of htib for now.
P.S- Don't tell me to audition multiple systems
Usually it is other way around.. Ppl ask for differences..
Is it the lack of AV dealers in your city/town? Anyways you nailed it..
Good choice.. I have heard the Taga Harmony 606 at a FM place with Pioneer VSX 1131 AVR and was good... Hard to beat a 5.0 speaker for 25K, where other brands FS alone start from 20K..
Pioneer would suit your needs and the speakers that you have in mind.. Pioneer VSX-330 AV Receiver
Hmm..More music.. Have you considered stereo amplifier?
IMO, a speaker package like Taga harmony 606 5.0 is much better than Yamaha yht 299 5.1.
I have heard the Yamaha YHT299 at my friend place.. Taga Harmony 606 will surpass it easily.. It is a much better speaker than the Yamaha satellite speakers..
If you don't have the budget for sub-woofer, not a big deal..you can settle for 5.0 now.. The FS in 606 will provide you with decent bass..
Thanks for the confirmation of my choice. And, yes there are no dealers in my city, I'll have to go with a decision to buy.
Also, I didn't get what you were trying to say when you said "stereo amplifier" ?
Do you mean 2.1 systems or systems without avr or anything else?
I looked around for pioneer avr and I found vsx 329 and vsx 330 to be in my bugdet. Both of them satisfy my requirements as far as I can see. Also, I don't see much difference between both of them.
Kindly help with the decision.
The 331 is the latest series, so go in for the 330 if available....check with a couple of dealers and negotiate a good price....
If music use is more than movies, ideally a Marantz would have been better but that's beyond your stated budget...if considering, look at the NR1506.
Yes. 2.0 (or) 2.1system.. Marantz PM6005 Integrated Amplifier
Kindly help with the decision. Thanks
330 is last year model from Pioneer.. You always get good price/deals on the outgoing model, hence the suggestion..
I read a lot of comments on durability and service of Yamaha AVR being better than Pioneer.
1) Is it true?
2) I'm getting Yamaha 3067 at 25k, Is it better than Vsx 330 (same price)?
3) Do they have option for an active sub ?
Both Pioneer and Yamaha have options for active sub....
You need to check the features, specs (output etc) and make an informed decision.
1) Is it true?
If you feel Yamaha is better when it comes to service, you can choose based on that..
Yamaha is also good..
Yes..
What's the difference between integrated amplifiers and AVR+speaker system?
Go thru this thread.. This might help you.. Or some more threads in the forum sub section..
http://www.hifivision.com/surround-amplifiers-receivers/40709-avr-vs-amplifier-dilemma.html
http://www.hifivision.com/surround-amplifiers-receivers/53062-avr-vs-stereo-amplifier.html
Brand consideration
Brands like Yamaha, Pioneer, etc. have service centers across India, no need to worry about it.
Integrated Amplifier vs AVR
If you want to setup 2 channel audio system, then Stereo Integrated Amplifier is what you need. No Dolby Digital or DTS like multichannel cinema audio.
If you want to setup 5.1 channel audio system (i.e., Home Theatre) then you need AVR.
I do not think that one should start comparing one brand over another.
Servicing near you - its important
Every brand makes low, mid and high end equipment's. And make no mistake on considering that every brand equipment's require servicing at some point of time.
Durability depends on your way of usage as well.
If you will search in the forum then you would come to know about problems users had in every brand. For example, one of my friend got HDMI problem in his 2 weeks old Denon X2200.
Active Sub - Almost every AVR supports Active Sub, few support Active as well as Passive both.
Few Considerations - Entry Level AVR's may not have these features
* Those who have crush on lossless audio, would like to check if front panel USB supports HD audio playback. Its useful to have this feature available.
* Speaker connections should be neat, clean and tight.
** Spring terminals get corrosion soon and cables may come out if wire is stretched...
** banana plugs cannot be used with spring connectors.
** Whereas screw type binding post are good in terms of clean and tight cable connection and different types of speaker cable connectors/plugs can be used.
Hope this would help!
Yes..
can anyone please tell what are the pros and cons of the two types of systems (avr and amplifier)?
Purpose - 2 Channel (L & R) Audio, mainly MUSIC
+ve: Great for music, better music performance than AVR
-ve: No multichannel audio, no surround
AVR
Purpose - Multichannel Audio (5.1, 7.1, etc) - Mainly movies (Dolby Digital
+ve: Actually made for movies
-ve: Good for music, but not better than dedicated stereo (integrated amp)
Hope it helps.
I'm also planning to upgrade my yht299 with taga harmony 5.0 speakers.
*Whether my choice is good or suggest me some other...
*If yes, 506 v2 or 606 v3?
*These taga harmony speakers are gud enough with the stock yht299 sub or do I need to upgrade my sub too?
*If yes, suggest me a sub.
*My AVR is 3 years old. But still working good.
Thanks advance.
Sent from my Moto G (4) using Tapatalk
Thanks advance.
I believe YHT299 AVR may not be good match for non-satellite speakers, however there is no harm in going step by step and find out your own likings.
You already have HTiB, first you can decide and buy your speakers and setup with your own AVR to find out if it could squeeze in enough juice and provide punch and power to your speakers.
If you have not heard the speakers yet then better would be to find out demo near you. You may also take your AVR with you if they don't mind to provide demo with your own AVR.
If you don't find your AVR suitable then you can go with another AVR.
I found a person gives his experience with his yht 299 with taga harmony. So that I too planned to upgrade mine.
I have replaced my stock speakers of YHT 299 with Taga Harmony 506 some one week ago with Yamaha sub only. Have noticed huge repeat huge increment in sound quality particularly with movies encoded with at least DTS sound. Since then whenever opt for a downloaded source have been downloading movies only with DTS or superior sound. Taga 506 certainly gels well with 3066 AVR
So.... Can i go for taga harmony 506 v2?
Someone rightly said in other thread, one person's meat might be other person's poison so please make a considered decision. With YHT 299 AVR I have noticed substantial improvement in sound quality with Taga 506 V.2. However, other factors like room size, speaker placements etc also do come into picture which might substantially alter the SQ in two different cases. As far as combination goes, they go well along well. No doubt.
