Suggestion for avr to go with Taga harmony tav 606 v3 5.0
Someone rightly said in other thread, one person's meat might be other person's poison so please make a considered decision. With YHT 299 AVR I have noticed substantial improvement in sound quality with Taga 506 V.2. However, other factors like room size, speaker placements etc also do come into picture which might substantially alter the SQ in two different cases. As far as combination goes, they go well along well. No doubt.
At first I planned to move to totally different AV experience which is DTS ATMOS or DTS X. For that it will take some more time bcz of the budget. But while reading in hi-fi vision, i found the capability of taga harmony with 3066. The budget is also reasonable. So that I changed my plan and want to slightly upgrade the av experience.
Dude.. Meat can be poison, to human. But in the case of AVR, if your 3066 supports taga then my 3066 too support. Room size can be the difference. But what I want is... The change of speakers should give huge difference in listening.
Sent from my Moto G (4) using Tapatalk
Hi friends I am confused between taga harmony 606se and klipsch quintet 5.o.
Can any one help me to take disision?
Sent from my SM-G615F using Tapatalk
If you already have a sub & budget is not a constraint, then Klipsch..
If you don't have a sub, then Taga 606 SE..
Actually my most use of this 5.1,for movies 60% & for music 40% . As per my choices, l prefer Crisps and clarity instated of Boom sound. But i like floor standing speakers which is not available in klipsch quintet. Budget not mor then 55k. You can also suggest me another option if u have.
I have a subwoofer 250w
Since you already have a sub, a FS is not reqd IMO.. Sub does it better than FS..
In that case you can settle for Klipsch itself..
Consider if this interests you..
For Front Left & Right - https://www.hifimart.com/taga-harmony-platinum-s-40-bookshelf-speaker-pair.html?search=Taga&description=true
(or) if you need wall mounting, you can consider this - https://www.hifimart.com/taga-harmony-platinum-s-90-sl-bookshelf-surround-speaker-pair.html?search=Taga&description=true
For center - https://www.hifimart.com/taga-harmony-platinum-c-100-center-speaker.html?search=Taga&description=true
(or) https://www.hifimart.com/taga-harmony-platinum-c-90-sl-centre-channel-speaker.html?search=Taga&description=true
For surrounds - https://www.hifimart.com/taga-harmony-platinum-s-100-surround-speaker-surround-speaker-pair.html?search=Taga&description=true
All this should be with in your budget..
Hi friends, after so many discussion... lastly I purchase klipsch rf 24 speaker package and denon x1300. Is it right choies?
Please help me about sources of good quality sounds and pictures...
I have 5 Dolby atmos movies in my laptop. Approximately 20 to 30 GB per movies. For batter picture and sound quality , is it mandatory to purchase a blue rey player? Blue ray players is better than laptop because my laptop is usable to play atmos movies smoothly. Please suggest...............
Congratulations! That's a big upgrade as compared to your previous choices. It will surely satisfy you. Bluray player is certainly not mandatory at this point. You can consider it later if buying original discs, especially 4k. You can save for OPPO 4k UDP range.
Then presently which sources i use to run atmos movies and music ?
My laptop is usable to play atmos movies and music smoothly. Presently I haven't 4k tv.
If your laptop is able to play the movies smoothly then no need to change. If it is not working you can go for media player box like Himedia q5/q10 pro.
Can I go for Sony bdp1500? Is it support 7.1 chanal sound ? The Suggestion provided by showroom technician.
You will connect this bdp to AVR by HDMI which will then decode the audio. So bdp won't have to decode it. In any case, it supports dolby true hd and dts hd, as per specs. But just don't get a bdp on recommendation of sales person. It may not add anything for you at present, as you are playing downloaded files in laptop.
Sent from my ONEPLUS A3003 using Tapatalk
I'm getting the Taga harmony tav 606 v3 5.0 speakers. Kindly suggest me an avr to go with it at around 25k price range. (movies :music - 25:75)
Also, I'm still confused about whether to buy a complete 5.1 package(yht 299) or a 5.0 mentioned above and avr for around same price. I've heard that it'll do the equivalent work of a bass of htib for now.
P.S- Don't tell me to audition multiple systems
As far as the speakers are concerned, Taga5.0 is definitely far better than satellites in yht299. No dout in that.
Hi elangoas,
Wanted to go with Taga Harmony 606 SE version. But have been thinking that floorstanders produce more loud sound in my room. I want to get deep sound and crystal clear voice. Above combination looks better for my room(14X10)? I will buy BIC PL 200 sub.
What about Platinum ONE Bookshelf Speakers instead of S 90 SL?
Anybody using platinum series? Are these better than Dali Zensor 1 or QA 3010,3090 speakers?
Hi elangoas,
A sub will be louder than a FS for bass..
I want to get deep sound and crystal clear voice.Above combination looks better for my room(14X10)? I will buy BIC PL 200 sub.
If you are planning for a BIC sub, then you can skip the FS and consider smaller speakers..
Platinum ONE doesn't have wall mount capability, which means you will need to buy a stand or keep it on TV table unit..
The S 90 SL has wall mount capability, IMO should be versatile for any speaker location (Fronts,center,surrounds)..
I use few of the Taga Platinum series, LCR 60 SL as surround in my set-up, Dual subs (SW 10v2) and Platinum ceiling speakers TCI 100R..
Taga Platinum series speakers use Metal tweeters.. From atleast what i have noticed, the highs have more presence, but not sharp..
Hi elangoas,
Thank you. Between Taga Platinum, QA 3010 and Dali zensor 1, which speakers are better?
Assuming you would pair one of these with a sub, i would pick the least expensive of the three, Taga Platinum..
Just because your are spending 2 times more doesn't mean you are getting a premium product here In India..
