Suggestion on Stereo Setup
rajivaryan1984
INDIA
Hello FM's,
Greetings. I am planning to create a dedicated stereo setup only for 100% music listening in my living room. I am planning to use the CXC series which comes with the network streamer and CD player and add CXA80 as the power amp. For Speakers I am planning to use my FS Dali Zensor 7. Since I am a bit bass lover, also planning to use my Sub for Music which is SVS SB1000. Kindly advise if this will be really a good setup for my music listening or if I am doing something wrong with this investment.
Also, I already have PM7005 and CD6006 and was thinking to use it with Zensor 7 ? Would you recommend this would be a good setup and I should not sell them.
Please tell me what best I can purchase to achieve the desired output like this -
Hello FM's,
Primarily the quality of music depends on room acoustics. If the room acoustics have issues, then no matter how expensive setup it is, its ought to make you unsatisfied. A lot of audiophiles keep changing the gear to get that "perfect/desired" output. A dedicated room preferably rectangle shaped is the way to start, and then later treat the room to remove echo and add reflectors/traps accordingly.
Once this is achieved you can focus on speakers first that fits your budget and room acoustics followed by an integrated or separates or mono blocks and a good DAC and source player(SACD player & Turntable) :)
thanks
Ravi Kumar
Personally, I would stick with your marantz and Dali combination. CXN streamer would be a good addition as it opens up many options. CXC is just cd transport and CXA Poweramp is really not required. Existing 6006 is good enough as a CDP.
Yes, room treatment is good....but if you are happy with the SQ, then don't loose sleep over it. Cheers.
Hi, Dali Zensor 7 and Marantz PM7005 is a great combination, but if you like bollywood music then you need to add an active subwoofer also. I have been using this combination for few years and fully satisfied.
