You have a very good budget. Can look at denon 8500 ,Marantz 8013, Yamaha 3080, Anthem 720 etc which are top line receivers alongwith good speakers such as B&w 800 diamond, dali, focal, MA etc. Key is to audition and then decide.
| Speakers LCR | Procella P6 | 135,000 |
| Speakers Surrounds (4) | Procella P5 | 65,000 |
| Speakers Atmos (4) | Paradigm CI HOME H65A Angled In Ceiling Height Speakers | 18,000 |
Since you have a good budget for speaker, kindly look at Triad speakers as well. I have heard Procella and they are very good but Triad is better .
Suggest you hear the XTZs to be sure.....there are quite a few members who use it and from what i heard it is a really good sub.....
each one of us would have our own preferences and expectations...hence recommended to audition with your music / movie clip as reference and then take a call.......spending almost 3-4 lacs on subwoofers is a huge investment.......
Taking demo of subwoofers can be very misleading.
Number of subs, integration, room size etc makes the difference.
For your room size .. First select 1 sub which is sufficient for that room size.. subs costing under 1 lakh will have enough power to play at reference levels in that room.
Then use 4 of those subs in your room to get clean , even bass.
Peaks can be treated with EQ. But only multiple subs can solve the issues of dips.
And yeah multiple subs helps reduce the perceived decay time of the lower frequencies.
Btw what do you demand from a sub ? Infra Sonic bass or super clean bass ? Or both![]()
4 subs properly placed and calibrated will give you more than you expect without drowning the dialogue.Okay. I wanted clean bass more, I don't like super loud vibration type bass that would drown out the dialogue also!![]()
The type of bass you are describing generally comes from a single sub or two subs placed together in a room.
Example:
Problem- When a movie is played you should get 100db at both 25hz and 40hz unlike a single sub giving 70db at 25hz and 100db at 40hz.
Solution: use multiple subs strategically placed.
Btw I had sent you a PM.. you ignored I guess![]()
Share your contact details if you wish to discuss.Good to know all this. Thanks!
Yes I saw the PM very late sorry! I was new to the website and the HT world in generalWe can discuss if you like.
| Component | Name |
| Projector | JVC DLA NX7 |
| Screen | Elite AR150H2-AUHD |
| Receiver | Marantz 8012 |
| Power Amp | Emotiva XPA-3 Gen 3 |
| Woofer x2 | Rythmik F18 |
| Speakers LCR x3 | CT 7.3 LCRS |
| Speakers Surrounds x4 | CWM 7.5 |
| Speakers Atmos x4 | CCM 684 |
Fantastic. Please share ur feedback with pictures of possibleHi, This is the final setup I went for:
Component Name Projector JVC DLA NX7 Screen Elite AR150H2-AUHD Receiver Marantz 8012 Power Amp Emotiva XPA-3 Gen 3 Woofer x2 Rythmik F18 Speakers LCR x3 CT 7.3 LCRS Speakers Surrounds x4 CWM 7.5 Speakers Atmos x4 CCM 684
Thanks everyone for your help and support!
Fantastic setup.Hi, This is the final setup I went for:
That's a very good setup. Congrats.Hi, This is the final setup I went for:
Fantastic setup.
Any acoustical treatment?
