Thank you very muchThat's a very good setup. Congrats.
Nice setup. Enjoy and do post your impressionHi, This is the final setup I went for:
Component Name Projector JVC DLA NX7 Screen Elite AR150H2-AUHD Receiver Marantz 8012 Power Amp Emotiva XPA-3 Gen 3 Woofer x2 Rythmik F18 Speakers LCR x3 CT 7.3 LCRS Speakers Surrounds x4 CWM 7.5 Speakers Atmos x4 CCM 684
Thanks everyone for your help and support!
Where as Subwoofers are concerned, I currently have the SVS PC 2000 cylinder subwoofer. My room size is 14ft length & 11 feet widht & height. The PC 2000 provides more than adequate bass in the room effortlessly without sounding boomy, overbearing & without taking much floor space. But the height of the PC 2000 is 34 inches. It sounds beautiful for 2 channel music & powerful for movies. You can also check the reviews of SVS PC 2000 on AVSForum by Mark Henninger. THe new SVS 3000 series is also supposed to be good with new 13 inch drivers. You can buy one & then decide if you need another one. Rel, Hsu, PSA & Rhythmic are other good brands.
For receivers you can consider Nad, Marantz/Denon or Arcam.
For surround Speakers Dali, Dynaudio, Focal, Mission, Tannoy, Klipsh, KEF
If you are in Mumbai you can purchase it from Alliance Four Audio, Goregoan west, , contact person Mr. Kadam . From Delhi the SVS dealer is Mr. Samay/Arjun, Audiophile India.
All the best.
Hi nitin...I use a small 8 inch sub in my HT setup due to space constraints. Then saw your above post.. So was just curious to know if the PC series cylinders need to be placed vertically or can they be horizontally mounted too. And what is their width please. Iam all wet and excited at the moment if I can sneak in a PC series sub lying down horizontally behind my side table. Thanks to kindly let me know![]()
Hi Newlash09, the PC 2000 needs to be placed vertically since it comes with sound path isolaters at the bottom to isolate rattle in the room. These are the dimensions of the PC 2000, 34.34" (H) 16.6" (W) 16.6" (D) . Basically it only occupies 16.6 inches which is compact but the height is approx 35 inches. My room is also small at 14 feet length & 11 feet width & height. It sits in the corner of the room so as to not cover the TV. Its more than enough for me with a lot more power to spare. For tighter bass it should not be placed in the extreme corner of the room.
For HT I am sure it will bring a smile on your face as it goes really low to 16 HZ & with room gain even more & I am more than happy for music too. If you are coming to Mumbai you are most welcome to hear it at my place.
Wow...thanks a ton for that advise nitin. Just got your PM too. Much appreciated
Will have word with my wife when Iam back, when she is not cutting any vegetables with a sharp knife. And see if I get a approval or not.![]()
Whenever we meet..the beer is on me![]()
Wow, its a killer system you have, and the Rythmik's sealed 18s are great subs. They dig deep and are good for both music and movies. Can you share the net price of the Rythmik subs?Hi, This is the final setup I went for:
