deeps007
You are right. I really liked it thoughThe price of the Prime Pinnacle in the States is approx 1.4L so that's almost a 50% premium.
Find another dealer, else take the plunge. The heart wants what it wants! Who am i to state otherwise?You are right. I really liked it though![]()
How much discount(in percentage) should i be expecting from dealers? Any rough/average figure that dealers can go down to? I don't have a reference point so i don't know how much should i settle in for? Please help me as i am getting calls from the dealers i went for audition and i don't have any idea what should i tell them.Find another dealer, else take the plunge. The heart wants what it wants! Who am i to state otherwise?![]()
That entirely depends on your negotiation and research skills. Many a times, I've not asked for a discount if the price was right. I usually consider US/UK prices as a good benchmark.How much discount(in percentage) should i be expecting from dealers? Any rough/average figure that dealers can go down to? I don't have a reference point so i don't know how much should i settle in for? Please help me as i am getting calls from the dealers i went for audition and i don't have any idea what should i tell them.
You can get 3700 for 1.12L with bill and warranty, my cousin got it last week. Feel free to PM me for more detailsI let go of SVS prime pinnacle as it is overpriced as compared to USD and no dealer is offering less than 2.10 lakhs which is beyond my budget.
Next in line is Polk R700 for which the best prive being quoted for 1.8lk (usd is 2200 on amazon) by one of the dealers in Noida.
Please let me know if it is the right price?
Also Denon avr-x3700h am getting at 1.2 lakh.
Are these price OK?
Hi Pratyush,You can get 3700 for 1.12L with bill and warranty, my cousin got it last week. Feel free to PM me for more details
If you have tested both of them using AVR, choose the option that most appeals to you. AVRs typically don't maximise the performance of the speakers.I have zeroed in SVS prime pinnacle & Polk R700 tower speakers with Denon AVR x3700h. Could you guys help me select one of the two speakers?
Does anyone have experience with either or both and help me decide which one I should finally go for? R700 is costing me 10k cheaper but I am unable to decide.
My use case is 60% movies and 40% music so I would need an AVR.If you have tested both of them using AVR, choose the option that most appeals to you. AVRs typically don't maximise the performance of the speakers.
So which AVR would you recommend for these speakers?I would think of getting a better amp as the specs for both speakers make them seem like a harder than average load to drive. If you still wish to use the above amplifier then look for speakers with a minimum impedance of 5-6ohm so as to keep yourself and the amplifer smiling.
The prime pinnacle is nominally rated at 8ohms which is a standard load. Do try and figure out its minimum impedance.So which AVR would you recommend for these speakers?
Powerwise, Denon 3700/4700 would be adequate as long as they work well with the speakers and your preferred listening style. Since your preference is for watching movies, a subwoofer is needed to deliver the deep bass and rumble as stated by FMs. Bass presents acoustical issues that need to be tamed, but that would be the next step after purchasing an AVR and speakersMy use case is 60% movies and 40% music so I would need an AVR.
With most IA's, that'd be a problem.Powerwise, Denon 3700/4700 would be adequate as long as they work well with the speakers and your preferred listening style. Since your preference is for watching movies, a subwoofer is needed to deliver the deep bass and rumble as stated by FMs. Bass presents acoustical issues that need to be tamed, but that would be the next step after purchasing an AVR and speakers
I wouldWith most IA's, that'd be a problem.
With an AVR however, Room EQ would tackle it.
If I'm not mistaken, the new line-up of Marantz AVRs get DIRAC also in addition to Audyssey XT32.
Came across this lab report from hifinews website, thanking them for their hardwork.The prime pinnacle is nominally rated at 8ohms which is a standard load. Do try and figure out its minimum impedance.
Going by the images you shared in the first post for the preferred placement, I would rather keep this avr or a similarly priced marantz/yamaha and spend more on the centre+sub and less on the left and right channel speakers.So which AVR would you recommend for these speakers?
I wouldon how well AVRs can tackle bass issues. If his budget permits, he should go for new age AVRs
I can go for denon x4700h or maybe Maranz 6015 as my budget for AVR is 1.3-1.4 lakh...
My max budget is 3 lakh and within this budget I want to buy AVR and a pair of good floorstanders...center and sub will come in later(maybe 6months to an year later).Came across this lab report from hifinews website, thanking them for their hardwork.
SVS Prime Pinnacle Loudspeaker Lab Report
Lab Report SVS may be better known for its subwoofers but the Prime Pinnacle gives every indication of being a carefully designed and, mostly, accurately specified loudspeaker. The one obvious exception to the latter is the quoted 8ohm nominal impedance which – as is all too often the case with...www.hifinews.com
Spend initially more part of the budget(or allocate more) on the centre speaker and the subwoofer along with the AVR as I find them to have a role thats more important in a home theatre setup.
Given your preference is more for movies over music and the avr won't really get the best out of the speakers anyway you can opt for a decent pair of floorstanders instead of spending more of the budget on them.
Have you auditioned any bookshelf + center + sub setup?My max budget is 3 lakh and within this budget I want to buy AVR and a pair of good floorstanders...center and sub will come in later(maybe 6months to an year later).
Or the other route could be a good bookshelf and AVR and then add sub+center later.
