After cleaning about 20-30 LPs in a seating.......your forearm muscles have been worked out
Cheers...
So there are two benefits, exercise and LP cleaning :lol:
Cheers...
Run tap water on both sides of the record surface for around a minute. This wets the record and allows water to seep well into the groove, and soften the deposited dirt and grime.
My only worry with this is the amount of water being used...:sad:
I use Amway car wash(which is very mild without wax or Silicon) mixed with 10% IPA and normal water with spray bottle.Car wash removes dirt very quickly and doesn't stick in grooves.I finally wash it with RO water.It provides me best result.
Sachin
Sachin
I've tried this too! and it is probably the best solution to use here in India....
Sachin
 Thought would add my experience to this thread, as I have used all the methods of cleaning vinyl mentioned in this thread
1. The Zero paisa method works well on relatively clean records but can also cause additional noise and deterioration in sound quality, it happened to one of the five guinea pigs that I had used.
2. Cleaning with a solution of IPA & Distilled water with a surfactant (Dish wash liquid; Amway car shampoo) and drip drying is a better method.
3. The solution that works best for me is using a 10 - 12 % solution of IPA in distilled water with a few drops of Triton x (as mentioned on a lot of web pages) and using a vacuum cleaner to dry out the record. I use a home vacuum cleaner for the same (with an air bottle in between).
The sound difference between the drip dry method and the vacuum cleaning is very audible and I cannot recommend it enough.
PS: IPA, Distilled water & Triton X can all be purchased at shops supplying laboratory equipment & consumables to Labs in colleges; schools & Industry.
am located in North Delhi and i sourced the Triton x (a 100 ml bottle costing 150 rs app.) from a lab supplies shop located in the Delhi univ. north campus area. There is a lane opposite Hans Raj College (If you are familiar with NC) which has a lot of these shops from where one can procure these ingredients, let me know if you are interested I may have the vendor's phone number which i can share with you on PM.
What a coincidence !! I stay like 10 mins away from Hans Raj .. We should meet up sometime man ... Its awesome to have someone staying so close to my place who has an interest in vinyls. Also do let me know the vendor's phone number.
Kartick
