anm
has anyone tried nuforce desktop amp?
Amazon.com: NuForce - Icon Amp - Desktop Power Amplifier (Black): Electronics
iaudio,
I think the topping has its power limitations, which are quite apparent in extended listening sessions. I'll post a detailed review in a while but just responding to the discussion on power:
I've listened to the TP20 with CA s30 speakers at a friend's desktop PC based setup. Earlier, he used to have a vintage Pioneer SX-650 ( an entry level model for that series) driving the s30s (90 db sensitivity). The Topping plays reasonably loud and has a good sound for 4K. However, compared to the 650 (35 watts), it clearly lacked the grip that the Pioneer had on the speakers. It was as if the tp20 sent music to the speakers and allowed them to do what they wanted. The SX caught hold of the speakers and literally orchestrated the sound. For want of a better description, it was like riding a horse gingerly, lightly holding on to the reins (topping) vrs. catching hold of its flowing mane and riding it steadily and with authority (sx-650). The topping sounds decent for the price but I am convinced that it will struggle with demanding speakers. The body, heft, and slam of the pioneer was just not there with the topping, even though the bass was more detailed. I would describe the topping as being 'leaner' overall in sound, the sx being more full-bodied.
So, in conclusion, the topping is excellent value for a desktop system or a very small bedroom system. However, it is not the best choice for floorstanders, large rooms or even as the amp for your main system. At the end of the day, 7 watts is 7 watts.
Of course if you want to be irrational and buy my speakers without listening to all these, who am i to object?(i can wholeheartedly recommend the combination though).
I am a bit surprised that it demonstrated this with a set of speakers rated at 90dB sensitivity though. But I guess sensitivity isn't all there is to it and perhaps the impedance that it presents to the amp is not very high, and then the little topping (with whatever current its PSU can send it) can only do so much.
Essentially in terms of power, with speakers, and in a setup where a few watts can do wonders, this amp will work great. If your speakers work well with an SET amp, it'll work well with this....and so on
pyschotropic,
The CA s30 spec. sheet says the nominal impedance is 4-8 ohms. With this wide range, I think that the load to the Topping will be demanding, in spite of the 90db sensitivity. This may be the cause of the lack of grip.
Srikarkav had a negative experience with the 9.2s, where one channel would drop volume. I wonder if anyone has tried the topping with the 9.1s. The tonal characteristics of the two may make a very good combination. I agree with you on your final observation - if a speaker works well in a low-watt setting, it has a good chance of sounding good with the Topping.
I think the impedance may matter more than sensitivity here. You may be right.
that would make sense. The Ushers in spite of their lower sensitivity have a measured impedance that almost never dips below 6 ohms (john atkinson's measurements in stereophile), and therefore presents a relatively easy load for the amplifier to drive, which may explain why it works well with the Topping.
If # 2 is correct then this would be good rather than badThe CA s30 spec. sheet says the nominal impedance is 4-8 ohms. With this wide range, I think that the load to the Topping will be demanding, in spite of the 90db sensitivity. This may be the cause of the lack of grip.
The published impedance for the S-520 is 8 ohms and stereophile is saying that the measured impedance remains ABOVE 6 ohms. So I'm assuming here that it would vary from 6-8 ohms. So are we deducing that varying impedance of 6-8 ohms is better than varying impedance of 4-8 ohms?The Ushers in spite of their lower sensitivity have a measured impedance that almost never dips below 6 ohms (john atkinson's measurements in stereophile), and therefore presents a relatively easy load for the amplifier to drive, which may explain why it works well with the Topping
Do we have numbers to define "steady" for the Epos?Steady impedance figures are what made my 3.5 watt tube amp work very well with my 87 db sensitivity EPOS M12.2 speakers.
1. I thought that all [almost?] speakers would present a different impedence at different frequencies.
2. If the above were true and if the impedance for the CA-S30 is 4-8 ohms then it would be a good thing for an 8 ohm speaker because because low impedance=high power and high impedance=low power - right?
OK - so in a nutshell, lower impedance speakers need higher powered amps to drive them optimally. Gottit!
Higher current, not necessarily power (watts)
2. If the above were true and if the impedance for the CA-S30 is 4-8 ohms then it would be a good thing for an 8 ohm speaker because low impedance=high power and high impedance=low power - right?
Indeed Hi-Fi has listed the TP20 again, this time with a lower price of $49.99 (includes power adapter as well): 2010 New Model TOPPING TP20 MK2 TA2020 T Amp + Adapter - eBay (item 290446622476 end time Jun-29-10 01:58:29 PDT)
