True Audiophile
Use computer to play music on using foobar. Get an iPhone or Android phone, download foobar app. Control music playout from foobar app via wifi. You can use a cheap netbook also.
Thanks Joshua. Computer/Netbook-DAC-AMP-Speakers+interconnects will be too much clutter & would not like wire jumble (Need to have space for vinyls :D). I guess there must be all in one box solution available where everything would be in one box HDD+dac+amp (100W output as universally agreed upon power requirement for listening).
Woa! It's been a busy morning on this thread :D
More than a digital/vinyl debate which cannot be resolved, I would be interested in a CDP/DAC debate which holds some possibility of being resolved. We have begun this debate many times on the forum but personally I opt out when arguments become convoluted, complex and confused. I woule love to read clear and concise accounts of various options for:
I'm sure that debate will go on, and I'm sure we'll be right there! But resolved? That it might not be!
CD is a collection of bits on a physical medium that may or may not have been subject to manufacturing faults and damage in handling during its lifetime. It is read in a slow, clunky way and I'm not sure that errors get corrected (I don't know).
HDD is a collection of [theoretically and ideally] the same bits (for the same song) on a physical medium that is fast and streamlined and incredibly accurate.
So, unless someone is going to wax lyrical about the silver disk (the light refraction is pretty!), at the level of storage, I don't think there is any competition whatsoever.
And before someone screams out, "But they sound different!" let me repeat that bit about the same bits. They do not, and cannot sound different --- and if the end result does (which it certainly might) then something else, other than the storage medium, is causing that.
So we can disassociate storage/transport and processing.
...Almost, but not quite: the CDP does have its timing of transport and DAC closely linked. Those who believe that jitter is anything other than the spectre of digital sound might quote this as giving first place to the CDP
Even then, at the point the data leaves the HDD, there will be misunderstandings and misconceptions and valid disagreements about what can, should, and does happen to it before it finally leaves a DAC chip as analogue sound.
I would rely on resolution any time soon :)
Till day all my experiments have not ended well with using a good Firewire/USB SPDIF converter with a good DAC Vs the regular CD transport.. the future is definitely based on Async USB DACs...so waiting for this whole "technology" to stabilize.
I wonder what was wrong. Maybe you shuld have tried simple analogue out from a good sound card! Maybe you did?
Gentlemen,
Dont you know when Audio CDs came out there was a mess of the job of digitization as engineers wanted to put in as much loudness as possible which resulted in less dynamic range and compression to the point of clipping.
I suspect that, at the start, the process wasn't properly understood, and was still being learned by the engineers, however skilled they might have been in analogue sound. I also suspect that this led to some very bad digitally-recorded/processed sound being issued on vinyl.
Compression (as in reduction of dynamic range to make everything sound loud) seems to be a sickness of more recent times. Music is produced to sell to the masses: the masses base their assumptions about what it should sound like on cinema, tv, and the ipod. It is unlikely that decent production values would even survive outside of niche music.
Let's assume for a moment that all the recordings of the past 50-60 years are stored in a 'digital bank'. Let us also assume that more information cannot possibly be added to the recordings stored in this digital bank. Therefore remastering can only filter out noise which may have been passed through at the time of the original transfer from analogue to digital. Perhaps audience noise can also be filtered out of live recordings. And perhaps along with the noise, some of the essence of music may also be filtered out. Therefore can the remastered CD's, SACD's and high resolution downloads be better than older recordings? Do they really provide enhanced sound quality?
The remastering/remixing and the digital format are two separate issues. I don't think there is a doubt that modern technology can find more in those old recordings, and present it better (to the cries of "unoriginal" from some). Having done so, what then is the role of the sample-rate/bit-depth in our listening? I don't mind those numbers being turned up just in case, but I would object to being charged more, because, hey, it doesn't take any more work to set the numbers higher when exporting the finished master --- it just takes a few more bits to store it. Thus, I see it becoming a marketing thing, not an audio thing.
The really good USB dace are expensive.. Although Siva at Acoustic Portrait has developed a really good one
Do they have to be? Watch that Ethan Winer presentation I linked to above. Note the experiments using a cheap soundcard. I found it an eye-opener :o
But we do love expensive. The choice between a PC case and something 10mm thick hand-milled from a solid block of metal? Hmmm... I think I'll go and google hand-milled PC cases! (:rolleyes: at self)
malvai said:
earlier i misquoted ultasonic frequencies as sub sonics.. while i meant that the body reacts to sub and ultrasonic frequencies in EXACTLY the same way. having said that, let me say this once again: the redbook format is devoid of such frequencies, while is why hardcore vinyl heads find that CD's just don't do it for them...
Yes, sorry: all of us make mistakes. Apologies for my reaction.
But still: the frequency response of your amplifier and speakers goes up to those dizzy numbers? Another reason I'm slightly sceptical about high-sampling-rate digital audio. And possibly part of the reason that live, acoustic music will always beat recorded audio hands down!
Naim Audio - British manufacturer of high-fidelity audio electronics could be the cure for you, though power output is 45W only.
Can this be one of the reasons that the same music generally sounds harsher at first listen on entry level CD players that on entry level TTs?
Yes, that is one of the best computer playback I have heard till date. But his own CD transport sounds clearly superior :licklips:
We once did this comparison.
- If the wave / Flac file being played is derived from a cd using EAC, then the original cd sounds slightly better if played through his transport. But this very slight difference is audible only if you use very hi-end transports. Comparison with mid level cd players will result in wrong conclusions.
On further discussion with Siva, he revealed that if one can obtain the original pristine wave or flac file for the song instead of ripping it, there is a chance that the digital file may sound better if played through a PC based transport and USB dac.
No it went on till as recently as 2008.
Loudness war - Wikipedia, the free encyclopedia
As for digitally processed sound in vinyl. If I come to know about it I would not like to listen to it.
Naim - the name demands respect.
hee hee power out put will not be the problem. Problem will be I have to sell few things, eat one time and move around in langoti* for few years.
*Langoti - A small piece of cloth necessary to move around in society.
Honestly I dont know as I am noob, but increasing loudness must be affecting overall dynamics of music/instruments. Suppose if there is a piece of music in a song from soft sound to loud, wouldn't everyone like to hear its natural progression instead of loud pieces getting clipped or compressed.
-x-x-x-
I will take a short break here as my work is being affected :) will join in after few days.
That assumes that either the CD, or the extraction, is faulty or inaccurate.
The audiophile world cannot change the laws of the digital world: data is data, whether it is a symphony or a spreadsheet. If it is wrong, then the data has become corrupt.
Confusion of different with worse? I wonder if a string quartet, playing in your living room. might sound harsher than an LP of the same music?
I wonder what was wrong. Maybe you sohuld have tried simple analogue out from a good sound card! Maybe you did?
I use an iMac ..so no options of a soundcard yet
But again, by itself the sound is good. its when you do an A/B that you feel the difference despite using the same digital cables.
My view may pretty much diverge with yours on this as well...but for me power is a very critical component for a DAC (from the impact of power on my DAC) and would really want to hear the difference between the soundcard and a good dac. but again never heard it so this would be pretty theoretical.
anyway ill be doing all this sometime in the future as my focus now is in getting my analogue rig to get working ... never realised there is so much to it .
Actually what you say is only partially true - yes errors in the cd can go undetected but if the accuraterip component of EAC works correctly, its almost impossible since at the end of the rip, EAC checks the checksums of the extracted tracks to ones submitted to the accuraterip database submitted by hundreds of thousands of users. If the checksums don't match, EAC informs you accordingly. Without accuraterip working, it is very very possible to have a badly extracted CD.
Also I'm curious what async USB interface exists in the Acoustic Portrait DAC? Any clue what chip it is based on? Did you use WASAPI while testing? Otherwise the results are invalid.
I honestly can't hear the difference between flacs fed by my m2tech hiface to the dac of my ayon compared to the stream unlimited transport on the cd player. The stream unlimited transport is fairly high end and exists on a few mega buck players like the flagship Wadias.
If bits are bits every CD transport mechanism should sound the same. While it is common sense that after all digital is only about 1,0 and bits there is a lot more to it. Using such extreme simplification may be good for the argument sake but not for the learning sake. CDs are not read as bits, but as words. What and how, please go through the Redbook standard to understand this concept.
Here is one of my latest experience with CD playback. Last week I went over to an audiophile's place to listen to his setup. I played some of my favourite CDs and it all sounded very nice. The CDP was a Rega Saturn. He then took out a small box, slightly larger than a CD. The same CD which was being played last, he took it out of the CDP and put it in this box, shaked it a little (for about 10 secs) and put it back into the CDP. I didnt know what he was upto. To me he looked like a crazy audiophile trying out some "snake oil" tweaks. But when he hit the play button I understood he is not crazy. Music actually sounded a lot more airy and lively. Can you believe it ? I tried it on 3-4 CDs and the effect was consistent. Everything remaining the same, why did the sound change. According to some people bits are bits, did he add any bits into the CD when he put it inside the magic box ? So here is the deal, that little box was an anti static case. It just removes static from the CD surface. Yes, you heard it right. I did not know this and if someone claims such a thing, most of us would consider him crazy. But it works. Supposedly it removes static from the surface of the CD which allows the laser to read the CD better. Now what does "better" mean here ? More bits ?
Anyway for those interested, I will post the detail of this product here. I forgot the brand and model number. I am sure it is not an expensive product but a tweak which works 10 out of 10 times and always is an improvement.
The problem is, for everything that I mention here in the forum I never give a link to a theory or article written by some XYZ personality. I only write what I have experienced.
When the experience is consistent, it becomes a belief. Deep discussions doesnt happen on the basis of blanket statements riding on internet articles IMO.
Interesting. I already want this magical jewel case too, and I already have an idea of making a mechanised shaker.
IIRC, vinyls are also supposed to benefit from anti-static treatment.
Joshua
Hi Jls001
You can place a small piece of tourmaline on top of your cd player. It pretty much will do the same thing.
... I didnt know what he was upto. To me he looked like a crazy audiophile trying out some "snake oil" tweaks. But when he hit the play button I understood he is not crazy. Music actually sounded a lot more airy and lively...
Hi Dr. Bass,
If this would have been quoted by a newbie, I would have surely dismissed this incident with a smile. Coming from your side, this must be "real", rather than "placebo" effect. Thanks for sharing this experience.
BTW is the "static" related sonic difference audible only in hi-end setups? (where each item in chain is above USD 1-2k)
Regds,
Hi Dr. Bass,
Regds,
Yes the system was good. ATC SCM20 paired with Naim Pre-Power. CDP was Rega Saturn. I cannot say what is the threshold level a system should be to enjoy this difference, but if it is not expensive it should be tried out.
Yes, the content of a CD is just bytes ... and if you feel the need to remove static from it, then touch it while touching something else that is earthed. If you are standing barefoot on a concrete floor, you probably did already. Touching the metal case of any of your hifi equipment, assuming a three-pin connection where the earth wire does actually go to earth would be good too. Quite good enough for handling genuinely sensitive (to destruction) items like PC memory.
Whether or not static electricity does have the potential to affect CD reproduction, I have no idea. Any studies? experiments? evidence other than anecdotal or non-blind testing?
Hi Dr, Bass
The test is invalid if you dont measure static build up before and after. I urge you to play that CD again after ensuring static build up. Since scientific equipment is hard to come by at home here is a simple procedure you can follow:
Play your favourite foot tapping music CD. Now Stand in the center of your room on a nylon carpet bare feet. Hold the CD in both your hands and fingertips at arms length like a steering wheel. Now dance and slide on the nylon carpet in a shimmying motion like a kid trying to splash muck in a puddle on his friends. If you are endowed with hair on your head, you can try balancing the CD on your head (most audiophiles aren't - they can't afford to be an audiophile until a paunch and middle age arrive). If you are the hairy gorilla kind I would recommend doing this naked for better effect. But make sure you pack the wife and kids out for shopping when you try this. This should ensure sufficient static build-up. When the music stops you should be sizzling with crackling noises audible all over your naked skin and body.
Now play the CD for an A/B comparison ( shake the box vs shake 'em nuts :D) and post the results. :ohyeah:
--G0bble
BTW, the question still remains, does the laser read less number of bytes when the CD was not treated with this anti-static box ?
