Two channel Music setup with BS and Integrated Amp
kkn
Tvm
Hello FMs Its been a while since I have been searching for a 2 channel music setup. I have narrowed down to three options listed below. (With Book shelves only- budget around 60K-max).
1. Dali zensor 3 + Yamaha AS-500 (Auditioned - liked it!)
2. Dali zensor 3+ NAD 326BEE (Yet to addition - finding hard in Chennai. Dealers doesn't have a demo)
3. PSB B6 + NAD 326BEE (Yet to addition - finding hard in Chennai. Dealers doesn't have a demo)
4. Any other good option in this budget?
Can you share your experience and thoughts on above combos? Thanks!
Music preference: Rock, Soft Rock, Classical, Jazz + Bollywood, Gazals.
Listening room: 12* 18 (hall)
Source: Mostly Pioneer BD player- Plans to upgrade to dedicated CD player later.
NAD and Cambridge Audio have good integrated amplifiers which are true audiophile performers...you may want to consider Marantz too.....
Personally I would prefer the Marantz first then Cambridge audio then NAD
Thanks efernand1! Will consider Marantz for sure. Will try to get an audition. Btw, which speaker will match better with Marantz (say PM 6004) out of the two (Dali Zensor 3 and PSB B6)? Are there any better options with in the same budget? Any suggestions?
For NAD & PSB, you can contact Raghu @ decibel in cenatoph road...(9940672834)... He used to deal with PSB & NAD..Not sure if he still deals with them now.. You can check with him....
For PSB and NAD, you can also contact Mr.Gajendra, Sowcarpet, Chennai.
PM his number if you wish.
IMO, Marantz or NAD + PSB - a good combination.
oh...Having any consideration for the used ones?
can you provide separate budget for amplifier and speakers?
