Tharun, apologies for causing more confusionHi
How about buying a Normal CDP like a Marantz or a NAD and adding a DAC like the Remiyo or Benchmark? Will that sound better then a high end Player?
Overall , below USD 4000. the whole problem with a transport/DACs are the power chord and Digital cable which can really impact the sound so much that getting it right takes time and money. BUT Dacs do give the adaptability to be a bit more futureproof as you can move to a other transports ike HDD transports. If you do have a large collection of CDs a box is a good place to start but if you plan to get into HDD then go the DAC way/
while a benchmark is a good place to start..you will need to do better than a NAd etc to use as a transport to get the best usage out of it...and standalone transports dont come cheap.
Finally buying a used transport/cdp comes with its own risks...from my (hard learnt) experience, unless it is from a known source or have easily available rtansport mechanisms. While DACS are much safer to buy used.
There is one great advantage to DACs ie they kind of futureproof a part of the investments..you can also feed it a HDD or any other transport as an input as well and very few CDPs have that feature. and that is perhaps the only reason i went the transport/Dac way
from your figure of 1 lac..you can get the benchmark as a DAC. use a DHlab Digital cable all for less that 60K and spend the rest on a a transport. I have heard that the chinese MHZ cd players have a good transport section.
all this can get confusing but i guess it is better to be clearer on you want now as this is a large investment !
