Truth is even if you put a component in, what you hear is the system ... and synergy between components is not so straightforward ! Also from a price point of view there is nothing which can beat used..as long as the seller is Trusted.
the Cyrus is really good as a cd player and so is the Primare. From a system point of view both the MF as well as the Quad are both on the Warmer, darker side so even a supposedly "thin" cdplayer will not sound thin on your system.
One advantage of the Cyrus, if i remember right is that it can be upgraded for pure transport duties too .you may have found the CD loading frustrating but it is just a matter of getting used to. believe me my CDM Pro2 can be pretty time consuming !.
Sorry for more confusion but in case the Ayon is above your planned budget,(BTW it can be used ass a DAC as well ! as it has a digi in ) I somehow feel you might just prefer the CEC TL51. it is one of the most organic cd players around although not the most detailed. another one i can think of in case you can find one is the Ayre CX7 which detailed and clean and organic...perhaps one of the best buys today.
In case you feel you are being forced due to lack of choice to your current choice, it maybe more sensible to hold of and wait till something comes up rather than rush into a sub optimal requirement just because it is the best available choice you have now.
My apologies again in case i have created even more confusion.
