darshanjoshi
It was available on Paytm for 1.05L with cashback.
I wouldn't trust paytm, call up vu toll free number and check warranty validityIt was available on Paytm for 1.05L with cashback.
Hi what did you pay for the 75incher
Vu pixlight 55 " is on it's way. Can someone help with the settings i should change?
Picture Mode Theater Brightness 52
Contrast 40
Color 42-46
Local Dim On
Backlight 40
This was at night Up to You
Tint 0 Sharpness 4
Ultra Smooth Off Noise Off
Adaptaptive Con Off
Color Temp Standard
White Balance Offsets R-3 G0 B4
Gain R-2 G0 B5 10
Point Level 10% R0 G2 B6 20% R0 G1 B1 30% R0 G1 B0 40% R0 G0 B2 90% R2 G1 B3 100% R4 G4 B6
Color Tuner Hue Sat Bright All Zero on all Colors Except for
Flesh Tones Saturation -4
Hi,I ultimate bit the bullet and got home VU 75 inch from a local dealer. Waiting for installation, shall share more info once it is installed. Anyone can let me know the best picture settings so that i can tweak it myself. I dont think so any forum has reviewed this model.
Could you please give your feedback on the tv as i am interested in buying the same.
Just wondering if these are really nice, or are Samsung/Sony more better?
Thanks!
This is for my TV 50K160GP. It May differ from other TV Models from Vu.
Go to Settings > Audio > select balance (should be 0) > type 1 > 9 > 6 > 9
you will see M icon on Top Left. Press menu again to access Service mode.
BE CAREFUL AND DO AT YOUR OWN RISK.
SOME OF THE SETTINGS CAN DAMAGE THE TV.
Hi.. I am also facing the same issue, I thought it is not connecting to Internet as I have changed my ISP...did you find anything on how to fix it?Hi guys , i have a VU android tv, I am unable to access the home menu or any android features since past two days. The tv works fine with dish tv. Can someone help me in resolving this issue? Is there a way to factory reset the tv without going to settings menu? Some sort of hard reset. Thanks in advance.
