What is the right approach for room treatment in high end audio ?
Yes
I know. But it's more effective than room treatment IME.
My experience has been very different. A mid-level speaker setup right usually sounds way more enjoyable than a high end speaker setup wrong.
Also, clever room treatment is only one part of the puzzle. Fine tuning the placement, isolation / coupling, adequate room size for the speaker are all part of the exercise.
But I agree that a good speaker is better than a bad speaker. In any room.
In my DIY pursuit, i have had the opportunity of using many speakers in my room. Everything else remaining the same, the change of speakers have had the maximum influence in the sound stage and realism. I have tried various placement, treatment etc. but nothing mattered more than the change of speakers in my room.
This should pretty much reflect the experience for everyone in the hobby when they upgrade. Once you have fine tuned your speaker setup for your room, if you change the speaker, naturally the new and better one will sound better.
I may be wrong but I think you are getting confused with the purpose of the thread. It is about improving speaker setup. Room treatment is one factor and the thread is about that.
To give you a better perspective, lets say your current speaker setup / acoustics ( hence results ) is bad due to various circumstances but the speakers are decent enough and you bought them because they sounded fantastic at the dealer setup or at your friend's house. Will you upgrade your speakers or work on the setup ?
If budget permits, i will change the speaker as for me they give me more benefit than room tweaks (which can be very expensive and ugly). Room tweaks can be very tricky and unless you actually know what you are doing it will be adding more issues than solving them. In my current setup, i have done a golden ratio setup for my speakers in my room, and noticed that this placement offered me minimum resonant sound in the room. Also my speakers being OB, the contribution of the room to the sound stage is very minimal.
Cool. This means you have arrived at your max tweak point with regards to room treatment as well as speaker setup. Therefore a speaker change makes sense if the current speaker does not satisfy you.
Squarewave has brought for an important point, room treatment. Has anybody visited audio shows where the bass is not booming and fast, considering bad hotel room acoustics? If you have, simply hire the person who has done this in a show and solve the problem. Guess work is of no help.
Website: https://www.kiiaudio.com/for_home.php
Where can I buy that diffuser which you see behind the table ? Anyone knows anything about how much this will cost ?
What is the best way to treat the wall behind the listener if the wall is less than 2 feet away ? Diffuser, Absorber or a mix ?
That looks like a vicoustic skyline type diffuser (I think they call it multifuser) in polystyrene. In Hyderabad Vectors carries them (i have seen black version in their showroom). I would guess pricing around 15-18k for a 2' x 2' panel (just an estimate, you need to call them to get a firm price). I bought 4 vicoustic wavewood diffusers from them a couple of years ago.
Sid
Sid
Are these required behind the front Speakers on every wall ??
A 6 ft by 10 ft will mean 15 pcs and that will cost rs 2.7 lac !
AFAIK, there is no hard and fast rule. Wall behind speakers, behind listening seat (provided you are atleast 8' away from them), ceiling first reflection etc are recommended. Compared to a broadband absorber these will not deaden the room as much.
Sid
