sure.. ask316
Received EX720 yeaterday and hope today to setup TV and DTH
http://photobucket.com/ex720
sure.. ask316
Pictures by karthikeyansh - Photobucket
AFTER A LONG TIME and more DISAPPOINTMENT
I have been purchased SONY EX720 on May.06.2011 at ICHIBAN, Chennai - 600 083 based on your website details and demo (Demo itself showed only TRUE HD content and not showed normal channels in all show rooms and displayed with FULL HD content, i forced to see on Normal channels). But, I have realized this model not worth even with normal HD-Ready LCD tvs.
As per specification said that MOTIONFLOW XR 200hz but it doesn't not even 60hz because of,
1. Not able to view one channel more than 5-10mins and appeared blur and ghost suddenly and disturbed more.
2. There is no reality but specification said that "X-Reality picture engine".
3. Eyes are increased and decreased rate of blinking while watching sports channels as well as other channels point #1 replicated.
4. Horrible when advertisement time, it show just like low quality set but brand name is SONY.
5. HDMI cable not suitable and no SOUND when plug-in (HDMI1 port), have to request or say obligation with cable during to plug in. ONE of another FRAUD with AIRTEL-HD DTH setup box. In my experience facing both time poor picture and sound quality produced but advertised HD-Quality Channels. But, better normal cable connection quality.
6. Based point #5, SONY can say its all happening based on Airtel HD set top box, but i would like say i had discussion with unqualified Airtel customer care for last 2 days and found better quality then to analyze more about your SUCKING model. Meanwhile i have ordered new HDMI cable and tested,
A. HDMI-1 fails to connect and no audio The same as found with AIRTEL HDMI cable also but not consistent. But new HDMI cable is consistent.
B. Other HDMI port can able to connect and hear audio.
7. While connection USB, message stating that to move out USB carefully while ejecting/remove, till the time i have found information how to remove safely on using with i-Manual and hard-copy manual. REAL HARD while SEEING YOUR LED TV.
8. For your fortune i never tried 3D and Internet option because normal content displayed like as simple 3D content so don't have time to spend other features.
9. ALSO CANT ABLE TO VIEW EVEN 15 FEET distance.
10. At that time of purchase every minute said will come demo and installation for wall mount next day or 48 hours. No one came my home till date for Product demo and wall mount installation.
11. Have worked with CENT, FlatHDpanel, Digitalverus picture setting, all are waste to set and view. ALREADY MONEY WASTE now TIME WASTE.
I have changed HDMI cable and better quality received then earlier but have still blur issue while watching exclusive for ZStudio, PIX, Hindi and tamil channels.
Whenever advertisement more disappointment in this TV....
Will decide action to take against SONY... i really disappointment and tried all points.......![]()
I have no idea about DVD's.. I have seen PUBLIC ENIMIES and too good but end of scenes got Blue color in middel and tried out once again but got the same..
Then played in CRT on same scenes no issues...
USB port tired some what.. but not seen full movie because of no interest to view... all are spoiled with this model..
but lot of call to Airtel last Sunday then updated High Resolution on my DTH BOX. If you need for High resolution send SMS "HR <customerID,if you have multiple box>" to 54325, other mobiles like VF send to 8800054325.
Hi can you please share your picture settings. I dont think this is a bad model. I think you should reset the setting to factory settings and start again. Dont compare hd to sd as sd will always look bad compared to hd.
your comments made me to think twice about 46"ex720...which i was planning to buy
If set correctly its one of the best out there.
I have seen this tv its excellent on all parameters except for 3d.
True and thats why i am surprised that kk is saying its a bad tv. This is the tv i want to buy.
He is upgrading from a CRT,this is not the first time i have seen people complaining about new HDTV after they upgraded from a CRT.
A HDTV be it a plasma or a lcd/led will only show how poor the source is.
I can see artifacts clearly on a CRT when connected to airtel STB.
