Which is SONY EX 720 / Panasonic D25B / Panasonic V20 /Samsung 6 series /LG?
I watch SD on my 2007 lcd and its looks as good as the Sony CRT that i have.
On the other hand with airtel it doesn't look good with either a CRT or a lcd,one can see artifcats even on the tiny 21" crt screen.
I have returned set this morning...
2 technicians came y'day and today.. but not clarified my questions..
It poor to view other then HD relay and it may called telecine judder
Did you play around with the motionflow and did you also enable Film Mode/Cinema Drive/CineMotion .
Almost exceed level... Every day played setting only even watching programs. But Judder clearly visible while watching Advertisement and Serials..
I clearly said same to technicians but they said it look like same because of Airtel HD box. But, i have clarified with Airtel and there end everything fine (Who knows). They said it may Motion Flow is ON but it same when OFF/Standard/Clear/ClearPlus. Also, more conflict for Motion Flow..
They said it very fast moving only applicable but it should 5:5 pulldown from 24 frame/s video is possible weather speed or normal (to reduced at the cost of introducing small visual artifacts)
it very difficult to sat with this Tv's and finally through way to show room..
I knew it very hurt.. one brand disturbed more mentally and physically last 25 days...
Still they stand no problem on their sets.. but they described because of normal relay.. then why recommend Airtel/Reliance/TataSky..
You are saying you saw judder in serials and advertisment.I haven't seen such judder even with a base model like BX300.
It could be a fault from airtel HD box.
