Hi Friends,
I needed your advice on this. I know that auditioning is the best way to go but due to the ongoing covid conditions, it may not be possible to do that.
Currently I am having the SVS PC 2000 & I am very much satisfied with it for movies & it's decent for music though may not be like a sealed sub.
Although it occupies very less floor space it is tall & is big for the room (14 feet L X 11 ft W X 11 ft H.)
Hence I would be going for a sub with a smaller form factor & reasonably light in weight (less than 35 kgs) to shift it just in case (looks like age is catching up). The above mentioned subs are on my list & I am open to other brands as long as they sound good for movies & music as my preference for both is 50:50. I don't mind sealed or ported as long as they sound good for both. I do understand I may not get the best of both but somewhere close is also fine.
I know that the SB 3000 would go much lower down but I am assuming that the quality & articulation of the bass in the Rel may better( I may be wrong on this). Hence I don't mind sacrificing low frequency extension for that. I have heard a lot of good reviews about the Rythmiks, but the good ones seem big & heavy. If there is a smaller one which can pressurize the room size then great. The above subs are in a similar price bracket. Thank you.
Nitin
Nitin
