Which Sub under 40k for Norge Concerto Gold 1000+Indiq Diamond Mishras?
DJPrajaxx
Hyderabad
Hi All,
With your advise and after going through count less number of posts, I took the pill and managed to start my hi-fi journey with Norge Concerto Gold 1000+Indiq Diamond Mishras+ a WIIM Mini. I want to add a sub under 40k, which one would pair well with my setup any showrooms in Hyd that I can go for a demo?
Thanks in advance.
Hi All,
Congradulations on your acquire. Have you checked with Amit of Indiq audio about the Sub. They have passive subs with seperate amp and they can specifially tune it to match with the Amp and their speakers, based on your room and sound preferences.
For music a sealed sub would be ideal, not sure if you may get any better sealed sub under 40k . Please check used gears also in olx or similar platforms if you are okay with that.
