Now thats what I would call a good sub for music. 15” and sealed.Skilful FMs,
I’m looking for a 15” Sealed Subwoofer. If anyone one of you can build me one or have any leads I’ll be grateful.
I would be happy to discuss this further via PM.
Thanks & Cheers
Yea. I’ll have to shift my cot out and sleep outside.Have you checked out this thread?
SVS pb2000 Duals to JBL 4642a wow
Don't waste your money in svs pb2000 they lack mid bass not good for music movies sounds okish im dint measure with rew i trust my ears but placement never helped they gave only backpain. pb2000 are hyped up. So don't waste your money. Stay away take an audition to believe. I live in interior...www.hifivision.com
Something to think about!![]()
Sadik only makes enclosures no? I would also like guidance on the enclosure size and driver selection.assuming you have reached out FM Sadik..
now banned (?), kanwar had some good builds... He seemed to have good tech know how... Not sure how to reach him though.. Perhaps manav can help..Sadik only makes enclosures no? I would also like guidance on the enclosure size and driver selection.
HiSadik only makes enclosures no? I would also like guidance on the enclosure size and driver selection.
My first preference would be for someone to build it for me.Hi
If you are interested in learning designing the speaker by yourself,
please take a look at this post (yes it is my own thread on diyaudio):
and start using speakerboxlite app. Get a few drivers simulated.A 3 way design study
A 3 way version to make it easier without having to split to 3.5 way, it might even be a little bit better. Looking a bit like a poor man's TAD Reference One.www.diyaudio.com
Then we can all chime in with suggestions..
PS: I personally would love to see some DIY effort going on in this forum. It is mostly due to lack of it or the interest that i have shut up and not posting anything here
I did try the app. This was one of the drivers that showed up.@aeroash: The reason why I suggested to read only the post I linked is because other posts can be distracting to your requirement of selecting a driver for your subwoofer.
Anyway the purpose was to get introduced to speakerboxlite app which can be used on a phone. The inputs to that app can be desired box volume (from the perspective of max. sized box that can be accomodated at home). Selecting brands of drivers that one is interested in/available in the country. Selecting bass alignment like bass reflex or sealed etc. These are specifying your requirement at the highest level not going into sealed alignment nitty gritties.
Selecting drivers first may not be a good idea. As you have described in previous post, thinking of application first is the way to go (eg: you want sealed alignment, no requirement for high SPLs etc). I don't know why you are interested only in 15inch drivers though.. Why not 12inch or even 18inch?
The driver you listed maybe a good driver but maynot be naturally suitable for a sealed alignment that gives reasonably good SPL levels. For this, we need to do a simulation to understand more.. Let me try using the app and see if it gives some useful recommendations.
Ok.. This is good. I will do a more detailed simulation of this woofer in a sealed box once I get my personal laptop today and post here..I did try the app. This was one of the drivers that showed up.
I have no space for an 18” driver in the room. I already have a 12” sealed sub. I thought I’ll dabble in something one size bigger just to see what it brings to the table when compared to my 12” sub.
Thanks @Vineethkumar01Box volume specs:
It says one needs to have a 105 litres volume available inside the box (with stuffing inside) for the driver to give the kind of output levels power handling etc shown in below plots
This is perfect! Lovely speakersI know how this bass sounds as I have 4 x Satori WO24P-8 9inch woofers in a very similar alignment at home as shown below
This bass is sort of quick. It is there one moment and then it vanishes. If the room permits, it doesn't linger around much. I really like it especially with music (i dont see many movies anyway).. Everyone may not..If one is looking for hard hitting "chest thumping" window shaking bass, this is not the driver or the bass alignment to look for..
Now the question is who is going to make this box for making this subwoofer
So I made an enclosure calculation based on dimensions shown in below pic to get the volume of 105 Litres. I have roughly allocated some 2 litres for volume taken up by driver and 8 litres for volume taken up by bracing. Depending upon the bracing scheme, these numbers vary a littleThanks @Vineethkumar01
That’s 3.7 cubic feet. That’s doable.
The box size works out to be 18” x 18” x 27”.
Does the shape of the box matter?
This is perfect! Lovely speakers![]()
Hi aero... there's this known guy called Mr Sethi who's running firm called 4d furnishers in Delhi. He would be great to connect with and can build a value for money solution for you. DM me for his contact infoMy first preference would be for someone to build it for me.
If there are no takers for the project, then I can build an enclosure myself, with inputs from FMs for driver selection, and cabinet size.
I read your post and several others from the link you posted. It’s all Greek to me.
My requirement is a sealed box with a 15” driver, mostly for music, with the occasional “slam” for movies. I do not care for loudness. All that matters to me is tight, well-articulated bass. This will be placed in an 11’ x 11’ room.
I would highly appreciate any guidance on this project. Please understand that you’re talking to someone technically inept in this matter. I will not understand any of the technical jargon. I will try my very best to keep up. I can follow instructions well, so please let me know how to proceed.
Shooting in the dark, with zero knowledge of drivers, I came across this piece.
I also found the box suggestions as follows:
Sealed box of 3.0 cubic feet with stuffing has and F3 of 45Hz and F6 of 34Hz.
Am I on the right path?
I found a drawing shared by @keith_correa on another thread. https://www.hifivision.com/threads/the-bargain-hunters-subwoofer.57800/post-855296A key aspect of woofer/subwoofer cabinet is to brace it well.. Now we want some one to draw a box with these kind of dimensions and decide the bracing scheme etc..![]()
I have Crown XLS 1502 with High/Low pass filters built in. Will this work? If this works then the passive build will be relatively simpler.Also, it is to time to start thinking about power amplifier for this, crossover/low pass filter etc.. You need a minidsp and a separate amplifier or a plate amplifier with filter cut off frequency adjustment etc for all this.
What are "Vents" in the measurements? is that for a ported box?Keeping all these in mind, coming up with an estimate of cost is also important..
Thanks @rwnano . @Vineethkumar01 has gotten me excited enough to execute this build myself, provided I have all the information to go ahead. Basically an idiot's guide to DIY. So far I have been able to grasp whatever has been spewed,Hi aero... there's this known guy called Mr Sethi who's running firm called 4d furnishers in Delhi. He would be great to connect with and can build a value for money solution for you. DM me for his contact info
Yes. This kind of bracing scheme should work perfectly well. Also it is not much of a problem if you make the box slightly bigger. (The alignment will change a little bit but not dramatically in this case as we are already shooting for a near to max flat alignment with Q close to 0.69).I found a drawing shared by @keith_correa on another thread. https://www.hifivision.com/threads/the-bargain-hunters-subwoofer.57800/post-855296
Will this work?
This amp seems to be able to put out a pretty good amount of power, which seems like it is more than you will ever need with this subwoofer. I haven't used this amp so no personal experience. But from the looks of it and it ability to incorporate filters also, it seems plenty fine for the purpose under consideration here.I have Crown XLS 1502 with High/Low pass filters built in. Will this work? If this works then the passive build will be relatively simpler.
If you notice the "number" of vents. It is kept as zero. This means it is essentially a sealed box.What are "Vents" in the measurements? is that for a ported box?
As long as I stick to the box's volume, I can play around with the dimensions, right?
The bracing does not need to be as elaborate. Bracing like this is less complex, uses less material and is as effective. And all strips can be separate ones just as long as they are glued to each other at the points they intersect.I found a drawing shared by @keith_correa on another thread. https://www.hifivision.com/threads/the-bargain-hunters-subwoofer.57800/post-855296
Will this work?
