Having become very attuned to a pair of bookshelf speakers with a subwoofer, I very recently got a very easy to drive pair of full range speakers. I perceived that they do not go as low as the sub at similar listening levels and I found myself turning the volume knob up to higher levels to perceive the bass better,,,,
This made me wonder if the lack of base frequencies leads to louder playback?
Thoughts?
May take on your 'issue' is somewhat rather different from what has been expressed....
1. You have actually provided the clue in your First Sentence itself, which I have highlighted.
You have (unfortunately) become attuned to a sub woofer, which IS the Problem.
IMO a Sub woofer will NEVER integrate well with a bookshelf speaker, its 2 different birds singing Very differently. The Sub woofer will sing its own tune, and never merge seamlessly with the Bookshelf.
The Sub Woofer has its place in a Home Theatre System, which requires exaggerated Bass, to wrench the brain's attention from the Video to (atleast partially) the audio. IMO a subwoofer is a misfit in in a good quality Hi Fi system, unless it is used to CUT
Room Resonant bass.
A bookshelf speaker is ideal for small rooms that cannot handle an extended Low Freq reproduction, which typically causes room resonance. Taking a bookshelf and adding a subwoofer is, I believe a bad approach. Better to buy a floor-stander from the same manufacturer as the bookshelf.
Of course Bookshelves also offer potential advantages like excellent imaging, but for serious HiFi you must live with the limited LK response.
2. Different speaker brands have their particular "House Sound" that the designer wants to emulate. Each house sound strives towards a particular goal, which may or may not be what you are looking for. That is why it is essential to audition a speaker (preferably in your room) before buying it. Never buy a speaker based on its paper specification, they NEVER tell the whole story.
I have heard only 1 Zu Audio Speaker, that too only once. From what I recall, Devore speakers' forte is their musicality & midrange.
Their House Sound is a bit 'Lean' or even 'Bass Shy'. So use it for what it does well. Do Not judge a fish on how it can climb a tree!
No Speaker can do Everything, remember Draupadi wanted her husband to have all the Great Qualities, she was warned, she insisted, and as a result got 5 husbands !
Also
the Review Posted in this thread clearly mentions the need to place your speakers VERY Close to the wall
"you can place DW6 as close as two inches from the wall behind it."
Placement close to the wall provides Bass Reinforcement. A corner placement will provide even greater LF reinforcement. Try paying attention to the speaker placement, you will get far more bass.
The 300B amplifier with these speakers should really make them SING... accept the somewhat lean sonic signature, and enjoy the Musicality and magical mid range.
You have got used to an exaggerated level of Bass from a Sub-Woofer, you need to re-calibrate your ears, and pay attention to what the rest of the frequency spectrum also brings to music enjoyment. You will be richly rewarded.
