Some photo of the blue and brown wire as they are leading from the drive terminal would help. Also photo of the plate amp would help. Are there any fuses on the plate amp board?I am in the same boat. One of my SVS SB2000 sub is not turning on. I opened it up yesterday, appears plate amp. is damaged. I disconnected the plate amp. I have some questions on trying to connect to an external amp:
1. There are 4 wires (2 blue and 2 brown) connected to the driver.
2. On the amp side - each blue and brown are terminated into a quick connect, so 2 quick connects, and connected to the amp board.
3. On the driver side only similar coloured wires, that is brown and blue are connected to the terminals.
My question, when I connect to an external amp, I have to form similar coloured wires into a pair right and connect to the amp. speaker +ve and -ve outputs? I wonder why they are mixed to the plate amp connector?
Also should I be worried that there is no EQ etc. being applied by this direct connection? I will be using my receiver cross over so only 80hz and below signals will travel to the sub amplifier.
Thanks,
Sid
EDIT: I found this from google search. The brown goes to positive terminal on the speaker (red dot on the terminal). There are two wires for each to increase the current carrying capacity.
