WiiM PRO
I am not sure if video itself has been doctored , by changing any of the parameters except power supply. I am assuming not 🤞
Oops. My mistake. I thought you made the video and hence I was asking. I have a bad habit of glancing at posts and reading it very fast. So I missed out the part where you say "you were watching this youtube video"
So someone else has made the video and hence we cannot know how it was made. I don't think it is doctored. My guess is that the two videos were made at different times and the position of the recording microphones were not at the exact same position.
I was absolutely intrigued by the difference because I have done these tests and I find no difference that my ears can make out.
@chander sir,
I was watching this you tube video and I was impressed with Shanti. But back then I had other use case of using it with pi4. Now it is for Wiim pro.
Please check with headphones if this is making a difference to you. May be your apple charger is good enough.
Apple chargers are good. But I don't think it will be as good as a nirvana smps.
That video was created by me. Right.. it has not been doctored. This was made after i had purchased allo shanti and was impressed by it. 🙂
Lovely. And I see you are from Pune. We should meet sometime and do few things. Maybe get few other folks. More the pair of ears better. Do some double blind tests for cables, power supplies , etc. Or just meet and listen to some music
Same song, another video i had created.
There is no shanti here.
The recording of the previous video was done on note 5, and i realize it is more clear.
This video was recorded on a different phone, which is inferior to note 5.
Sounds nice. What song is it?
You mean 1A?
Even I had doubt about it , but ppl on wiim forum says its draws max 1.5 A and min 0.5 and p50 is just in middle of it. SO I think it might work
See here
@MaSh already using this.
Yes I did. I did mobile charger vs Allo Shanti and I felt soundstage a bit wider, darker background , crystal clear and a bit more meaty vocals and may be a bit tight bass(But it may be due to isolation applied under speakers too) with Shanti.
Are you using digital out of wiim pro or dac output while using Allo Shanti linear power supply?
Did you try with Shanti? Please post one with Shanti too.
it is non deliverable to my place through amazon
I got it delivered by Amazon.com to a relative in US, who then couriered it to me via USPS. It will be subject to custom duty after it arrives in India. On rare occasions, the custom officials may pass it, otherwise be prepared to shell out anywhere between 45% to 75% during on invoice price + shipment charges. I had to pay around 6500 as duty.
" WiiM ULTRA " - Guys, will it compete with Eversolo, hope time will reveal it :)
By the time it is revealed and available for sale, there would be another new streamer making its way.
Technological improvements and new devices won't stop coming out, get what is available right now is the best practice I feel.
