Searching a centre speaker
satimis
Hong Kong
Hi all,
I'm searching a centre Wharfedale speaker to pair my Wharfedale column Left and right speakers and found following models;
1)
Wharfedale D300c Center Channel Speaker
https://www.wharfedaleusa.com/collections/center-channel/products/d300c-center-channel-speaker
2)
Wharfedale Diamond 12.C Measurements and Review
Please advise which model shall I select?
REgards
Hi all,
1)
2)
REgards
What may sound pleasant to me would possibly sound bad to you! Everyone has their own experiences and expectations.
It is highly recommended to audition before purchase. Just keep in mind, the center speaker does most of the work to deliver accurate dialogue clarity with some punch. Ideally should be a 2.5 way speaker. Honestly does not matter to try another brand.
The Sub will do all the bass heavy lifting besides the L+R speakers and the rest (surrounds / heights/ etc) will work for the effects.
If you have shortlisted the above 2 models, compare the specs and take a decision. Recommended to audition same movie clip or song before purchase. All the best1
Thanks for your advice.
My problem here is no audition
