Denon x4800h new humming noise
I have panasonic 4k player to the left side inside tv unit some 4k disks inside plastic box on right side and tv on top of tv unit thats it
Humming noise is due to electrical circuit grounding issue or any electromagnetic field close to the unit. There are ferromagnetic beads available in different sizes on amazon. Apply those to the power cable of avr .this should cancel the noise
Disconnect everything including the tv from the power source and power up the Avr alone. See if you are still getting the noise
I removed every plug but did not help. But i put bluray player out it was not touching tv unit wood there is i guess no hum . Can you tell whats is happening
