Speaker surrounds damaged - JBL Control 1 pro
bobbyprajan
Kochi
While moving the speakers to another room, I found the surrounds of the JBL Control 1 pro has disintegrated so much that it comes off when wiping it with a soft cloth. It was used as PC speakers and listening to FM radio. The damage on one speaker is more than on the other one
Should I try to get this repaired or get another set of speakers ?
Hi bobby!
few years ago I faced the same issue...
Foam surround is common in the JBL Control 1 and i have 2 Pairs lying to be refoamed bought from a local HFV member which he has not used it for long time and unfortunately i have also not checked the package before buying.
Three months ago I replaced the foam surround of my 8" Russian FR driver with a DIY goat skin surround and the trick worked. I have been using the speaker since then without any issues. Also a cloth can be used as surround if getting a goat skin is too much of a hassel.Have fun.
I am not confident of doing this myself. Will get help if I am able to source the repair kit. The repair kit from the ebay link seems expensive.
The rubber covering on top and bottom of the cabinet is coming off. Can I scrape it off completely ? It is a sticky mess
Not able to decide whether to go for a new set of speaker instead of investing in the repair
There are 100s of surround replacement videos in YT and is not rocket science. All you need is some acetone to remove the damaged surround and glue, a cutter to scrape old glue and some rubber based glue like fevibond. Any old used cloth which is a bit lossy can double as a surround. You need a steady hand and a inclination for DIY.
Instead of repairing, why not replace the driver itself? Unless they are super rare or expensive to get.
MaSh
