Topping TP20 tripath 2020 amplifier (versus NAD C320BEE)
psychotropic
In your opinion, VFM bookshelves one can audition with the topping - besides the Usher/Wharfedales? i am looking at something less than 20k - even better if the amp is included in that price.
I am shifting to a new place which has a really small living room - so thinking of getting the topping paired with BS for my music tastes - rest the TV can take care off i guess, given the room 'size'.
Cambridge Audio S30 (and recently the smaller S20) match the Topping well, for music and volume levels. For a small room or desktop system, as long as the speakers are away from the wall, the combination sounds very nice. This is from personal experience.
The CA S30 are not available at least in Chennai it seems.
sri
Thanks ajinkya
could you help me out with the tentative pricing of the S30?
Unfortunately, I haven't kept up with the latest pricing but I recollect a friend getting them (s30) for around 8K INR sometime last year. The s20 will be cheaper, of course.
The Topping Tripath Triamping Trial
OK, after all the drama and flap, finally got the second set of Vifa XT25 tweeters! Had them delivered in the US, and an obliging B.O.B. carried them back home.
Had to find out how they sounded, so I dragged out my mothballed, superannuated Pioneer CS-88 boxes and promptly gutted them: disconnected the crossovers, soldered 18-gauge cables directly to midrange and woofer (ignoring the tweeters & supertweeters), threaded the twin cable pairs through the erstwhile binding-post holes, shoved the fibreglass blankets back in and screwed them shut. Then soldered cables directly to the new tweeters' tabs, and plopped them on top of the speaker boxes still in the bottom halves of the packaging they came in (heresy!).
The other ends of the speaker cables went to the Toppings: one TP-20 for tweeters, another TP-20 for midranges, TP-21 for woofers. Minijack-to-RCA ICs connected the 3 Toppings to Xonar DX analog-outs. Had to buy really cheap no-name ICs, because all the decent ones have fat metallic minijack plugs and the Xonar's line-outs nestle together closer than virgins in a harem. These cheapo ICs have moulded rubber bodies, and I had to shave them flat-sided with a pocketknife so they'd fit alongside each other.
On my PC: Foobar2000 with the foo_dsp_xover plugin. Configured the xover with 2nd-order (12db/oct) Butterworth: Lowpass @ 150, Bandpass @ 150/2000, Highpass @ 2000, delay on Low @ 10ms - those ancient 12" drivers are slow!
Only minor stumble was the Centre/Sub line-out: couldn't use it because it sums stereo input to mono output. I think the Xonar is responsible for this. So even though it's an 8-channel card, only 6 channels are usable, really. And channel mapping isn't what the foo_dsp_xover indicates, either. In my case, xover channels 1-2 mapped to xonar channels 1-2, but 3-4 went to 5-6, 5-6 to 7-8, 7-8 to 3-4. Took a while to figure out what went where using my old Sansui amp and Bose bookshelves for the testing - didn't want to slag the new tweeters by mistake :)
With all the crossover parameters and the gain controls on the Toppings, there's so much leeway to play around with the sound that I'm still trying to figure it all out. Not easy, when one has dodgy aural memory :D. I'm playing WAVs that I ripped from my CDs with EAC. Right now, low-end lacks resolution and the imaging sucks, but I guess that's only to be expected considering how it's all just tossed together. Tweeters sitting in thermocole cradles! Speakers on wooden stools! But it's still early days with my new/old toys, so on with the tweaking...
Next I guess I should see how flat a response I can get with this setup in my little, cluttered, horribly reflective room. I have a basic non-IEC Radio Shack SPL meter, so maybe I could use that with a test-tone CD...
Then, how to best resolve the driver timing issue without having to blow more moolah on, say, thuneau's Frequency Allocator? Hmmm...
Anyway, here's what the trial looked like. Low resolution, because it's an old camera. And ignore the messiness; I usually do.
Uploaded with ImageShack.us
wow, this looks utterly fascinating. i do hope you tweak the babies till they sound perfect. all the very best!
Thanks! It was you and this thread that planted the triamping seed in the space between my ears in the first place, so :cheers:!
I was resigned to junking the old speakers - they were stacked in the passageway covered with an old counterpane - and couldn't quite bring myself to do it. But now they're starting to sound a little better the more I fiddle and run them; maybe they need some loosening up time after their long hibernation :)
The Toppings are very clean indeed on the highs and mids. Right now, they're set at 10:00 (high), 7:30 (mid), 12:00 (low), but that's comfortable for most music at my sweet spot 8 feet away. And the fiddling continues...
I am tending towards the 2022 chip (used in a Muse MU-40 Amp). Would it be much different, I mean, a bit inferior to the 2020 Tripaths?
The Amp is yet to be picked up by my friend who would be visiting Hong Kong shortly. So, trying my best to understand which would be a better buy.
Started looking at the 2022 due to the higher output of @ 60W ... instead of the 20W of the Topping TP20.
To be frank, am a noob at all this, hence asking time and again before taking a blind risk ... which, I usually happen to take off and on ...
I am looking to buy the topping.does anybody know how they ship?and whether they can send it to my place which is interior Kerala.And also how customs can be taken careof.I have no experience or knowledge about these matters.
Thanks in advance.
dear.....read the thread completly............you will find all answers.
Thanks in advance.
I have placed my order for TP2020 MK II on 20th August from the below seller:
eBay India: Topping TP20 MK2 Class T Digital Amplifier TA2020 New (item 280543847197 end time 02-Sep-2010 22:54:14 IST)
And I have not received them yet. Using the tracking number given, I can see that it is shipped from Singapore as Registered Mail on 24th August.
Can anyone please tell me how long it usually take to reach here and is there a way I can track the current status ?
AFAIK, the only way is using the tracking number you've been given. You might also want to see if it's arrived and sitting at a local post office -> Welcome to the Indiapost Web Site
I'd placed two orders for Toppings from China/Hong Kong via ordinary post. One order arrived in 4 days, the other took 17 days.
Good luck, and an anticipatory welcome to the Proud Owners of Toppings (POT) Club!
I checked with the local post office and they don't have any idea about the parcel. The postman told me that it might got stuck at the customs.
Is there a way I can contact the customs dept and check the status of the same?
^ Do you have a tracking number?
If so, check here to see when it left HK : http://app3.hongkongpost.com/CGI/mt/genresult.jsp?tracknbr=<tracking_number>
Usually, it reaches me a week after the item leaves HK. Sometimes, it's not the Indian customs, but the HK customs (due to the volume of posts leaving) that results in delays. If more time has passed, probably it's stuck with Indian customs. I don't know if this can be tracked with this :
http://ipsweb.ptcmysore.gov.in/ipswebtracking/IPSWeb_item_events.asp?itemid=<tracking_number>&Submit=Submit
Or try this - China Post Tracking - Trace EMS,China Post and Hong Kong Registered AirMail
Let me update you all about this ......
Wrote to Peter Cheung of Indeed Hi Fi labs. I had placed an order for Topping TP20 + Adaptor on the 20th Sept.
Recd email confirmation from him thru eBay that he has send the goods to Hong Kong Post on the 22nd Sept. with a Track No. .... with a note, that within 48 hours HK Post would be able to provide me a 'track'.
25th Sept., on checking with HK Post ... after feeding in the Track No. found that the goods is being processed for further delivery to India.
28th Sept .... same status. So, wrote to Peter. He replied, HK processing is minimum 5 days due to heavy custome rush. Then, 3 to 6 weeks to reach India.
I think, Registered Post makes use of the sea route ... and not by Air. Maybe, thats why this looooooooong wait.
*** Cursing my 'fatty' not-so-close friend who did not hand carry it back from Hong Kong .... could have saved the huuuuuge sum of $ 30 too, on shipping charges + this wait .....:mad:
Just now I received a letter from Customs Dept, India telling that they have received the parcel and there is no declaration as to the actual value/nature of the parcel. So I have to produce the Invoice /Receipt/ Bill or any like document showing the description, quantity and value of goods.
Also it is written in the letter that if i wish to claim exception from the customs duties, i need to submit the necessary documents.
Now I am going to contact the seller to get the Invoice for the same. What is the max value i can show in order to avoid any duties, so that i can tell the seller to mention that price.?
please advice.
